Team70R
Rear lift cable electric actuator
Team70R
Thinking about setting up an electric actuator for my rear hitch on my C165. I was wondering if I could put it up under the belly of the tractor and hook the rear cable to it and leave the manual lift handle for the mower deck. Would a 330 pound capacity actuator be enough?
elcamino/wheelhorse
I did something similar to what you are asking . Check out my thread " Separate Rear Hitch Lift " dated 7/27/2015 Includes photos of my work and problems I ran into. Good luck
Team70R
I just finished reading your thread! I love your setup! Definitely gonna try something like that! How's your holding up?
elcamino/wheelhorse
@Team70R Works great have not had any problems. Easiest way to install chains on the back  tires.  I have a piece of 6x6 , lift hitch , place the 6x6 under  the hitch , move to down position and the whole rear  lifts with both wheels off the ground.
The only major problem I ran into was the dang gas tank under the seat. Trying to position the actuator so it would not bind resulted in a lot of cussing.
Team70R
The down pressure would definitely be nice!!! I might try to go outside of the tank bracket. Is 4" of travel plenty ??
elcamino/wheelhorse
I went with 6 inch just to be safe. A rule of thumb is to double the travel measurement for the overall measurement of the actuator. I purchased mine  over the net and it has load capacity of about 700 lbs. I think I paid about $90.00 plus shipping.
Team70R
Alright I'll look at the 6" then!
  • Similar Content
    • BrianKoch
      By BrianKoch
      Gentleman, I’m in need of:
      Mower deck rod lift part # 6699
      (I really just need the rod, not the trunnion or nut)
      Thank you!
    • Southkraut
      By Southkraut
      Was looking to buy rear hitch assembly on eBay don’t know what is comparable with my ‘84 c125. They all look the same. Is there much of any difference through the models?
    • Team70R
      By Team70R
      Well I scored a free 4" linear actuator from a combine so I went ahead a built an electric rear lift. It's not the fastest thing but it definitely beats manually lifting! Right now it's just set up for my grader blade but I will be getting my cultivator and disc to work with it as well.  Blade lifts to almost 5"
