JoeBu 0 #1 Posted October 24, 2017 I have a 97 Wheel Horse Model 520 Hydro and am trying to install an older 42 inch snow blade. The model number on the blade is 6-2133 with serial number 153737. I'm not sure if this plow even goes with the tractor as I bought this from an estate and they just assumed the plow went with it. Anyhow, I tried uploading photos on this forum but keep getting an upload file error message. So is there a trick to uploading photos too, this is in jpeg format. Any help will be greatly appreciated. Share this post Link to post Share on other sites
SylvanLakeWH 24,122 #2 Posted October 24, 2017 Uploading photos is way easier and unlimited if you are a supporter. Click on "Store (Support RS)" on top of page and you can check it out... But no worries - I'm not a 520 guy but I know some folks who are 520 experts will be along shortly to point you in the right direction... You are in the right place! Share this post Link to post Share on other sites
shallowwatersailor 3,213 #4 Posted October 24, 2017 18 hours ago, JoeBu said: I have a 97 Wheel Horse Model 520 Hydro and am trying to install an older 42 inch snow blade. The model number on the blade is 6-2133 with serial number 153737. I'm not sure if this plow even goes with the tractor as I bought this from an estate and they just assumed the plow went with it. Anyhow, I tried uploading photos on this forum but keep getting an upload file error message. So is there a trick to uploading photos too, this is in jpeg format. Any help will be greatly appreciated. Because you have a later 520-H with a swept axle, the dozer blade that you have will not be able to sector to the side. Wheel Horse made a kit that would allow the frame of the attachment to be extended so that the blade could be angled. 1 Share this post Link to post Share on other sites
CasualObserver 3,406 #5 Posted October 24, 2017 https://www.wheelhorsepartsandmore.com/brackets-linkages.html#!/Toro-Wheel-Horse-520-Snow-Plow-EXT-Kit/p/84954631/category=23566571 Lowell @wheelhorseman one of the popular vendors has the kit available. As mentioned, the kit is required to extend the frame to be able to clear the swept axle. Share this post Link to post Share on other sites
rlrnot 39 #6 Posted October 25, 2017 Check out CL post I.D. 6278015844 Share this post Link to post Share on other sites
