bobinmaine 0 #1 Posted October 14, 2017 Hi. I just decided to do a bit of maint. on the ole horse( 77 B80 with 8 horse Kohler). Changed the oil, greased, added new spark plug and new coil wire. Started right up and ran perfect. mowed for about an hour then I shut her down . Came back about half hour later hit the key, not even a click. checked connections etc. jumped across solenoid and started turned over but No Spark. tried old coil wire still no spark. Any ideas? Share this post Link to post Share on other sites
JPWH 5,288 #2 Posted October 14, 2017 Losing 12 volt somewhere. Ignition switch or a safety swtch? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,441 #3 Posted October 14, 2017 Click on the picture. Then click on the small wiring diagram picture and it will enlarge. For a better look download the file. Garry 2 Share this post Link to post Share on other sites
SylvanLakeWH 23,802 #4 Posted October 14, 2017 Make sure your PTO is completely disengaged... Might be just the PTO safety switch... Don't ask me why I suggest (know) this... 3 2 Share this post Link to post Share on other sites
953 nut 51,015 #5 Posted October 14, 2017 Basic rule of trouble shooting; when a new problem crops up take a look at the last thing you did. In this case the last thing you did was mow which means the PTO lever was moved. We have all done it, some just won't admit it. 4 Share this post Link to post Share on other sites
clueless 2,893 #6 Posted October 14, 2017 25 minutes ago, 953 nut said: Basic rule of trouble shooting; when a new problem crops up take a look at the last thing you did. In this case the last thing you did was mow which means the PTO lever was moved. We have all done it, some just won't admit it. More than once . 2 1 Share this post Link to post Share on other sites
