Shea Worden
Belts
Shea Worden
Where can I find a good new drive belt for my wheel horse? I cant seem to find any online or anywhere else. I figured I would run it by you guys and see what surfaces.
953 nut
Take your old one to Tractor Supply and have them match it up to a new Kevlar belt.
  • Like 3
Shea Worden
Thanks. 953 nut, I didnt know that they did that. I have a few belts to match up.
fast88pu
Toro dealer. Replace it with an original belt. They do make a difference if you plan on pulling anything with it.
squonk
I have had 0 issues with TSC and Napa Kevlar belts for 30 yrs. doing any job asked of the tractor. Drive,mower, blower it doesn't matter. Just make sure you get the proper width as well as length.
  • Like 3
fast88pu
TSC belts aren't what they use to be then. I had 3 go on my 48" deck mowing this season. I will be sticking to the factory belt.
953 nut
Got to agree on the mower drive, haven't had the best results with Kevlar there ( one year and need replacement), but for drive belts to the transmission I have been very pleased with Kevlar.
squonk
I have 5 yrs on my Napa green PTO belt. Probably will install a new one next year. The only :wh: OEM belt I have in the fleet is the belt that came on my snow blower.
Shea Worden
How do I know if i am over working my trans? If I spin my wheels?
953 nut
Spinning your wheels is no problem. If your wheels had enough traction to never spin then the next weakest link would rear its ugly head and brake so a lack of traction is sort of a safety valve.
fast88pu
I broke a belt pulling last year. Had tons of traction lol
Shea Worden
Thanks. my tractor looses traction pulling heavy stuff where I feel like something would break.Now I know that I wont bust my 8-speed tranny.
Edited by Shea Worden
  • Similar Content
    • Bill D
      By Bill D
      Found these at Lowe's.  Same belts as TSC, just different packaging.  The 86" I got was on clearance and is not being stocked anymore.  They had sizes from 87" to 109" in 1/2".  Not a lot of 5/8" belts that would be useful for our tractors.
    • Ifixoldjunk
      By Ifixoldjunk
      I just bought a deck for my 310-8, it’s a 42inch rear discharge, it came with a complete parts tractor, but I need new belts for it. Does anyone know what size belts I need?
    • Tim Fenn
      By Tim Fenn
      I've just acquired a renovated C125 but unfortunately the drive belt got snagged with the mower deck belt (maybe because of incorrect fitment?). It looks like I'm on a steep learning curve! I've been trying to find out which belt to buy as a replacement. The belt I've just taken off is 94 inches but  according to the parts manual I need a Toro belt part number 94 2501 which is 103 inches? The mower deck is a 42in rear eject. It's funny that the Toro belt has 94 2501 as the part number but is 103 inches & I apparently need a 94in belt? Any ideas?
    • Shea Worden
      By Shea Worden
      Hey guys, my wheelhorse c81 got a new transmission last year and now it’s grinding when I drive. First thing the brake pulley is on a higher shaft and doesn’t work with the c81 brake rod and hardware. Second the bearing behind the intake pulleyhas fallen out, which I assume is the grinding sound. Is there a way I can fix it without taking the whole transmission apart? I don’t have enough knowledge to do that kind of repair. Thanks so much -Shea
    • CTR
      By CTR
      I have a 312 8 Wheel Horse that i have
      Had for 16 years and thé belts are thé ones that came on thé tractor.I am having problèm finding thé belts. Any hélp would be great.
