JeremyF
Dozer Blade Angle Handle
JeremyF
Good morning all,
I was wondering if anyone has a drawing or measurements for a blade angle handle that is bent to go around the brake pedal. I have a 412-8 and have a blade for it, but it has the straight handle on it so it blocks the brake pedal. I have the means to bend a new handle if I had a drawing or measurements. Thanks for the help!
Walt
Mine was bent when I got it and hit the brake pedal so I reversed the bend to clear it. Then some time later last fall T-MO needed help with making one for his. I posted drawings I made with measurements to his post asking for help. He then did 3D drawings of it. So I would suggest you contact him or look for that thread to see if that would work in your case.
Tankman
I cut one and welded a horizontal piece of flat bar in. Works great. :handgestures-thumbupright:
