Lost Pup
Lathe Made 42 Deck Pulley and Spindle
Ed Kennell
Nice work.   New spindle housings next year?      :thumbs:
Lost Pup
Not hard to make up a solid aluminum set on the lathe.
Can/should I soak the housings to arrest the corrosion a bit ?
Will it help ?
Ed Kennell
I don't know if soaking would help.    I am amazed how these housings are eaten away.   Sometimes I think there must be some kind of electro/chemical action involved.
KC9KAS
Very nice work.
I admire people with talent to use a lathe!
cleat
Very nice work. I am not a big fan of the stamped pulleys and yours look fantastic.
Please keep us updated on how well the aluminum lasts.
I hope you put never seize on the shaft so the pulley does not corrode to it.
Great job.
wrightorchid
Yes, mixed metals can corrode much more that if by alone.  Aluminum and steel together does cause galvanic corrosion (google it for much more info), much like steel and copper do (which is why you have to have a proper junction in plumbing).  There is actually a mild current flow that causes this.  This is worse, when the metals are wet, such as wet caked grass on the spindles and deck.
Lost Pup
3 hours ago, KC9KAS said:
Very nice work.
Thanks
I am self taught machinist. Books , You Tube and the Web are my sources.
Picked up my South Bend 10K Lathe off Craigslist maybe 6 years ago. $300 bucks from a local Retired Locksmith.
Trust me , i had had quite a few of those **** moments while using it.
Great job.
The new pulley is made from C1018 5 inch round Steel.
MalMac
Freshly cut grass clippings, especially damp green grass have a acid like property to them. That’s why the aluminum is eating away, plus as already said the mating of the two different metal caused oxidation. This is also sped up by the grass clippings. Wet grass when left stuck to the bottom  of a deck for any length of time just eats away at it. That’s why I scrap mine often and at the end of mowing season they get power washed before being put up.
Good looking lathe work. I’ve been making my own spindle shafts for some time now.
Lost Pup
The spindle is made from 4140 alloy steel 3/4 diameter.
I threaded the spindle on the 3/4 ( blade ) end and used Red Loctite to place the thin 3/4-16 Grade 8 hex nut in the proper location on the spindle. This saved from buying hex bar and turning the whole length to the 5/8 an 3/4 diameters.
I may cross drill and pin the lower 3/4-16 with the red loctite. No need for it to ever be moved once placed.
The blade side nut is grade 8 3/4 16 as well.
The pulley spindle end threading is 5/8-18. Grade 8 as well.
The spindle is cross drilled and I need to pick up grease fittings to finish them.
I also need the O rings for the spindle. Two of three were still there when disassembled but they just fell apart when rolling them off.
The bearings seem fine.....roll smooth. I did not remove them from the housings.
Should I pull the bearings to soak and clean them or leave alone. ??
I assume the inner grease shields are removed to allow the grease fittings on the spindle to purge them with fresh grease. Maybe just grease them heavily the first time ?
What do think ?
Thanks
Edited by Lost Pup
Lost Pup
Thanks
Raw material was well below items cost. I think the spindle and pulley were $50 apiece.
The 5 inch round was a cutoff for $20 and the 4140 3/4 was a long length for $25.
The steel shop did offer to face or cut the 5 inch round to width, I should/will do that in the future. It took forever to face of the extra 3/4 inch off the back side, filled the trash can with a huge pile of chips.
pacer
Heres an option that I'm now doing you might consider. Couple years ago I was replacing some of the bearings in spindles and after fighting/removing that huge wad of old grease and looking at those nice new 'sealed' bearings I'm thinking, hey, they are sealed for a reason I'm gonna leave the seals alone and try running them with out having to grease them (I had had a Yard Man and its deck ran with sealed bearing just fine) I've just finished up the 2nd season on those bearings and they are still going fine.
By the way, NICE lathe work! Aint it a good feeling to make stuff like that? I have a lathe and a mill and honestly I wonder if I could get by with my horses having to run down all the parts - I probably make 50-60% of my parts, bushings/ trunnions/levers/rods.....and, spindle shafts & pulleys!
Achto
Very nice work!!! :handgestures-thumbupright: :bow-blue:
cleat
My mistake, I thought it was aluminum.
Steel will be much better wear wise.
Give it a good coat of paint (hate to see your nice work rust).
I would still use never seize on the pulley to shaft and also on nuts on both ends.
You could likely make some money if you were to make those up and sell them.
You could also make the pulleys and spindles for the 48" deck as well.
Thanks for sharing your work with us.
Cleat
Sarge
If you can get those housings cleaned and blasted - using aircraft acid primer for aluminum and painting them will stop the corrosion - I've done a few of mine in the past and they still look good .
Sarge
ronhatch
Nice work! Now that I'm retired, I sure miss the machine shop I had at work!
Did you consider making the larger driven pulley about an inch smaller in diameter, say 4", to speed up the deck for a better mowing job?
Lost Pup
Possible I could just swap the double bagger pulley to the center. The PTO deck belt might be a bit long at that point.
A smarter guy would talk about blade tip speed and rpm. Comparing my Craftsman mower with the Wheel Horse decks, the Wheel Horse cuts and mulches much better to my eye.
Sarge
I going to give it a try. Waiting for ordered new blades, Metal Clean and Etch and Aluminum Primer.
I do have a sand blast cabinet with glass beads so I am set.
Edited by Lost Pup
Sarge
It will take some time with glass beads but be sure to get all that corrosion off - otherwise it can start again under the primer from moisture . My first try at these failed when the paint later flaked off despite using aircraft etching primer , the second try has yet to even chip the paint after I got them cleaned all the way to bare aluminum . That oxide layer is pretty deep - you'll see the layers of color change when you blast them .
Sarge
pacer
Sarge is right, getting all that corrosion off with glass is gonna be a lengthy process - and you'll have probably turned your glass to dust! Would be worth your time, and effort, to go ahead and get a bag of Black Diamond coal slag (TSC has it) -- My cabinet will only handle the fine grade....
Lost Pup
Just finishing off the thread....finally dug out the 42" deck and got it back together. That pulley looks nice in there. The deck wheels bushings  were egged out and the shaft worn oval.
Lathe made a bolt and two wheel bushings from some hex stock. The old grease was rock solid inside the wheel so I cleaned it and the zerk was able to flow grease.
Looking forward to see how the deck operate with that heavy solid pulley. I will clean it up and paint the deck over the winter.
Lee1977
I clean prime and paint the spindle housings when I do the same to the under side of the deck. Should be done ever couple of years I went 4 or 5 years last time, but the primer and paint sure does save the spindle housings.
I bored out the deck wheels and installed oillite bushings 10 or so years ago they are still doing well, looks like the rubber tire is going to ware out before the oillite bushing.
  • Similar Content
    • razorback1995
      By razorback1995
      Hey all,
      This pully blew up on me yesterday. Having a hard time IDing the part # or replacements. the 308-8 schematics I've found don't list this part.  Its the pully in the front that runs from the motor to the mowing deck.
      Thanks in advance!
    • Joe Warren
      By Joe Warren
      Mower Spindle Components
      mostly new old stock
      Prices shown do not include the cost to ship.
      Message me with your needs and any questions.
      Thank you.
      Joe
      PART NUMBER(S)
      DESCRIPTION
      QTY. AVAILABLE
      PRICE EACH
      103711
      NOS Spindle shaft assembly
      1
      39
      103711 (used)
      Used spindle shaft assembly
      1
      29
      101686 or 5875
      NOS Spindle shaft sub-assembly
      1
      49
      104890
      NOS Spindle shaft
      1
      49
      104982
      NOS Spindle shaft
      1
      44
      107998 or 107446
      NOS Spindle shaft
      2
      89
      109912
      NOS Spindle shaft
      1
      59
      112673 or 109965
      NOS Spindle shaft
      1
      59
      108849
      NOS Spindle shaft
      1
      89
      102780 or 104373
      NOS Spindle cups 1.0” tall
      2
      39
      NOS Spindle cups 0.9” tall
      2
      39
      102784 or 104374
      NOS Spindle cups 0.8” tall
      1
      39
      100289
      NOS Needle bearing, MFD USA Torrington
      2
      19
      101411
      NOS Ball bearing, sealed both sides, MFD China
      2
      29
      101480 or 1515 or 5493
      6
      9
      106084
      NOS Ball bearing, sealed one side, MFD Japan
      11
      9
      106085
      NOS Ball bearing, open, not sealed, MFD Taiwan
      16
      9
      106070
      NOS Seal spacer
      10
      9
      100674
      NOS Spacer-pulley
      1
      13
      107445
      NOS Spacer-bearing
      1
      9
      106069
      NOS Spacer
      1
      9
      110234
      NOS Lock bolt-pulley
      4
      2
      110242 or 908033
      NOS Lock bolt-blade
      11
      2
      915090 or 32146-20
      NOS Lock nut-pulley
      11
      2
      936028 or 32120-42 or 52-6640
      NOS Snap ring
      7
      2
      8389
      spindle housing
      1
      39
    • davem1111
      By davem1111
      I thought I'd circle back and see if I can fix a 42" deck (05-42MS05) that came off of one of my previous tractor purchases. I got the blades off and the bottoms of the spindles look good, and it needs some metal welded on where the wheel height adustment bracket bolts on. No big deal.
      The problem I'm having now on this deck is that I can't get this one spindle off. I haven't gotten the others off either, but they seem to be fine. This pulley is flopping around and obviously needs help. I've tried heating it with a torch after spraying it with penetrating spray numerous times, and it won't budge.  At this point, I'm thinking that I'll just need to grind it off, right through the spindle shaft, unless I can successfully cut through the thick ring without damaging the spindle shaft. If I have to grind through the pulley, it probably doesn't matter because I think it's shot already. Anyone have any other ideas?
      One question:  Is that thick ring supposed to be part of the pulley? This one is detached and the pulley spins freely (and sloppily).  Assuming I'll need to buy a new pulley, but was hoping not to have to buy another spindle shaft also. I did take the grease zirk off and have hammered on the top some, but only with a block of brass in between. It could already be damaged there.
      The picture doesn't help much, but here it is:
    • Joe Warren
      By Joe Warren
      one new old stock spindle housing
      part number 106063
      $79 includes shipping within US lower 48.
    • Bach-Ed
      By Bach-Ed
      I need a little part number help.   I'm looking for the part number of the idler pulley that tensions the drive belt on my 857.  The diagram shows the left side of the tractor.  And I can't seem to locate the pulley on the parts drawing.  The bearings have gone out on my tractor's idler.
