Sparky-(Admin) 19,284 #26 Posted October 16, 2017 12 hours ago, WHX12 said: Did you use the copper spray gasket then Sparkeye? I noticed some recent exhaust side leakage on a freshed up 10 hp of mine and just wondering if I should try it or just learn how & have the patienceto glass a head. I've got the same hiccup on a 1257 but it goes away with a little fine tweaking of the hi speed adjust screw or when under load. Probably has original points in it so new ones are not the worst idea either. I did use the Copper Spray that posted a pic of....I cant say that it helps or not, time will tell. New points are on my to-do list for the C-145. Share this post Link to post Share on other sites
Fordiesel69 188 #27 Posted October 16, 2017 Sparky, you will probably need to retighten once more in lets say 2 - 5 hrs. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 19,284 #28 Posted October 16, 2017 58 minutes ago, Fordiesel69 said: Sparky, you will probably need to retighten once more in lets say 2 - 5 hrs. I believe your right. I was a bit shocked by how much it took to get them back to spec after the first hour or running. Share this post Link to post Share on other sites
tunahead72 2,329 #29 Posted October 16, 2017 1 hour ago, Sparky said: ... I was a bit shocked by how much it took to get them back to spec after the first hour or running. Like, how much? Share this post Link to post Share on other sites
953 nut 51,015 #30 Posted October 16, 2017 It has been my experience that hot torque to the same 25 to 30 foot pounds may be a half turn or more. Share this post Link to post Share on other sites
Sparky-(Admin) 19,284 #31 Posted October 16, 2017 1 hour ago, tunahead72 said: Like, how much? It’s a half turn or less on EVERY head bolt. And I went to 30 pounds the first time I torqued them. Pretty sure I would have been looking at a leaky head gasket real soon if I had just torqued them once and never re-checked. 1 Share this post Link to post Share on other sites
