Walhonding520 25 #1 Posted September 30, 2017 520h is sputtering then dying on an incline or when I go forward from a stop quickly. Has more then half a tank of gas. Runs fine otherwise. Fuel pump new, filters New and hoses new. Any ideas? Share this post Link to post Share on other sites
woodchuckfarmer 333 #2 Posted September 30, 2017 Maybe you've got a little water in the gas tank. Share this post Link to post Share on other sites
953 nut 51,000 #3 Posted September 30, 2017 Did it do this before you replaced all the fuel system parts? Was that the reason for this servicing? Share this post Link to post Share on other sites
Walhonding520 25 #4 Posted September 30, 2017 I just replaced everything because it was old. I will drain tank and check filter in tank. If the screen was clogged wouldn’t it be a problem all the time other then just in an incline? Share this post Link to post Share on other sites
Jerry77 1,218 #5 Posted September 30, 2017 1 minute ago, Walhonding520 said: If the screen was clogged wouldn’t it be a problem all the time other then just in an incline? Yes...Your replaced the fuel pump with ? original style ? starving for gas for sure................?..sure sounds like the pump isn't working strong enough..how does it do with a full tank? Share this post Link to post Share on other sites
Walhonding520 25 #6 Posted September 30, 2017 It is better with a full tank but still not perfect. It’s not an OEM pump but it’s one that was recommended to me in here and it is same style. Share this post Link to post Share on other sites
520hC-120 136 #7 Posted September 30, 2017 Does it idle fine and does it need a carb clean? The fuel may be in the pump and lines but the carb might not be letting it through, my C-120 did this and I did a full carb rebuild and it go's up any hill fine now 1 Share this post Link to post Share on other sites
wfrpalm 216 #8 Posted September 30, 2017 Could be the float. Share this post Link to post Share on other sites
520hC-120 136 #9 Posted September 30, 2017 tap the carb with a wrench a couple times to free it up Share this post Link to post Share on other sites
Walhonding520 25 #10 Posted September 30, 2017 The carb in need of work but it has been working fine if I even it out with the choke. It is ok on flat or down hill. I’m starting to lean towards something in the tank or the float for the gauge. i did notice the fuel cap seems to have cracked and fuel does come out. Any way this is causing a problem? Share this post Link to post Share on other sites
953 nut 51,000 #11 Posted September 30, 2017 2 hours ago, 520hC-120 said: did a full carb rebuild and it go's up any hill fine now Sounds like solid advice to me! Share this post Link to post Share on other sites
Ed Kennell 35,143 #12 Posted October 1, 2017 3 hours ago, Jerry77 said: ..sure sounds like the pump isn't working strong enough..how does it do with a full tank? Will it back up a hill OK ? The pump hast to work harder going forward. Share this post Link to post Share on other sites
Searcher60 208 #13 Posted October 1, 2017 Could be anything. Remove plug wires from coil. Remove fuel hose from carb and insert into suitable container. Crank engine and see if pump fills container with gas. If not, find out why. Maybe install old pump and re-check. If container fills with gas, problem is elsewhere. I do not think it was smart to change working parts. Fix carb. Share this post Link to post Share on other sites
Walhonding520 25 #14 Posted October 11, 2017 So I took the entire fuel system apart from tank to carb. Found a piece of rubber in tank shutoff. Not sure how it got there so I’m taking the tank off and giving it a good cleaning. I’m assuming this will cure my problem. Thanks for advice everyone. Share this post Link to post Share on other sites
