Bill D 1,596 #1 Posted September 27, 2017 (edited) Hi, Does anyone have a part number and source for the input shaft seal on my 1992 416 H. This is the shaft at the top of the transmission that the motion control linkage connects to. The Toro part number I found on Partstree is 56-3130. If this is the right part number, it lists for $24.00. Is there anything out there that is better and cheaper? Thanks. Bill Edited September 27, 2017 by Bill D Share this post Link to post Share on other sites
953 nut 51,507 #2 Posted September 28, 2017 If you know the inside diameter, outside diameter and thickness of the seal you could get one from any good industrial supply house. Share this post Link to post Share on other sites
Bill D 1,596 #3 Posted September 28, 2017 I don't have the measurements, and I didn't want to disable the tractor until I had a seal in hand. Share this post Link to post Share on other sites
daveoman1966 3,586 #4 Posted September 28, 2017 Pats parts:.. $12 seal http://www.psep1.biz/arinet.asp?aribrand=TO#/s/TO//56-3130/1/ 1 1 Share this post Link to post Share on other sites
