rockerpeople
Ignition problem
I have a 1996 Wheel Horse 314-8 that has a Kohler motor on it. My issue is starting it. It does nothing for several tries at turning the key but finally starts. Seems to be getting worse. Makes no noise during tries to start; nothing till it finally kicks over. I've looked all over this thing to see if it is brake/safety switch related but find nothing. Help?
With any electrical problem the first step in curing it is to clean and tighten ALL electrical connections including grounds, this will clear up about ninety percent of them.
Thanks again to this forum. I will follow the diagram and chase these down and clean them as a start.
Another question; is the ignition somehow connected to the brake or clutch on this tractor that won't allow it to start unless brake or clutch is depressed?
There is a clutch interlock switch that requires you to push down on the clutch peddle to crank it over.
They went safety first on the newer tractors. My 2000 314-8 has a seat,clutch pto,and shift safety switch.
If any one of the safety switchs are not made it will not start. You can bypass the safety switchs one at a time to see if one is bad.
Possible problems  key switch ,pto switch,or starter.  I don't know if the 96 has a seat switch but there known to cause problems.
I would also check all wire connections
  • Similar Content
    • By bizzo15
      Decided to sell the 314-8, wife wants to mow the lawn more and doesn't like shifting gears.  It's a 97 or 98(i don't remember off top of my head) 314-8 hour meter says it has 261 hours but it's broken so if I had to estimate the hours I would 600-800.  Mechanically very strong with no issues, I've used it weekly to mow my lawn for the last couple of years.  Comes with a 37" side discharge deck and bagger setup if you want it(not pictured).  Only trades I'm really interested in would be a full hydro tractor.  Let me know if you have any questions.
    • By Ken-H
      1997 Wheel Horse 314-8. Runs great.
      42" side discharge mower deck
      42" single stage snow thrower. Includes wheel weights and chains.
      $200 each or $500 for all 3.
    • By dlaw90
      I have a 1999 314-8. It never starts on the 1st try whether it is hot or cold outside. It always starts immediately on the 2nd try. Is there anything I should be checking/fixing or is this just typical of a 18 year old tractor. The hour meter reads about 350 hours.
      If the tractor is stopped and restarted during mowing/plowing, it will start on the first try.
      This is my first tractor, so no response is too obvious...
    • By jjjharr
      Hey everybody, I just picked up a 314-8 with around 800 hours on it. When trying to put it into low range from high, the lever wont budge. It almost feels stuck, I cant figure it out... Thanks In Advance
