drewd
Start then no Start
drewd
Started on the 416-8 that I picked up two weekends ago (posted under tractors).  The PO thought it was the starter but that is turning fine.  I have been able to start the engine by jumping at the solenoid and it runs quite well for not being started in a year or more.  Seems really decent.  My issue is it may or may not crank with the key!  First thing to mention is the battery is charged. The night before last I turned key to start and it cranked but did not fire right off so I let up and hit it again.  This time it barely started to crank, then hit it again and nothing it just stopped trying (it acted like a dead battery from the first crank that gives you just a bit before getting worse on the second and nothing on the third try).  Last night gave it a squirt of WD 40 in the carb and plug then turned the key and cranked strong and started right up (as I mentioned the battery is charged but tonight it acted like it!) .  Then I let it run a bit to warm up going from slow idle to full throttle then back down.  Shut it off with key waited a minute and NOTHING!  Let it cool down to where the muffler was cool to the touch and still nothing.  Any idea where I should start?  Thanks!!
gwest_ca
You will find this file handy. Each circuit has it's own diagram. Click on the picture below.
Garry
953 nut
With any electrical problem the first step should be to clean and tighten ALL electrical connections including grounds, that will cure about 90 % of them.
SPINJIM
I had exactly the same symptoms two weeks ago.  Turned out to be a bad connector on the solenoid.    A little vibration or temperature change would break the connection.   If I jumped the solenoid, I was bypassing the loose connector.   I almost spent money on a new solenoid before I decided to check all of the terminal clips.
   Good luck,   Jim
oldredrider
Just finished fixing a 312 with the same problem. Long story short, solenoid was bad. Checked all connections first to eliminate that as an issue.
Bench tested the bad solenoid and it would not give consistent OHM readings when energized. Replaced it and problem solved.:)
drewd
The ignition switch is not great.  I cleaned it the best I could but one of the terminals is a bit loose.  It turns and starts right up but you have to be gentle with the switch.  I ordered a new switch and wire connector and fuse holders as they looked worse for the wear.  Thanks for everyone's help!
953 nut
:woohoo:             Hope that fixes it.
  • Similar Content
    • Rob R
      By Rob R
      Afternoon gentlemen friend of mine's father passed after a long illness, and he is now the owner of his Wheel Horse 416-8 with the Onan P216.  He wants to sell it to me as he has other tractors. I never owned and Onan Machine what advice can you give me. It has been in storage for 5 years and of course according to him "ran when parked" Has 365 hours on it. Thanks in advance going to look at it this Wednesday.
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • morePEdal
      By morePEdal
      416-8 with Onan P216 Engine
      The good:
      *576 hours
      *Nice, clean deck (42”)
      *Nice Plow
      *Wheel Weights
      *Chains
      *2nd owner. 1st owner sold the house in 2020 and said he was getting too old so he included it with the house.
      *Original receipts and paperwork and manuals.
      *Receipt showing tune-up and changing from the deck to the plow in November 2021
      The bad:
      *The last time it was used was the winter of ‘21/‘22. It is currently set up with the plow.
      *Had trouble starting, when it started, it died after 4-5 seconds. He had a portable charger and it helped. We got it running, but when I turned it down to idle, it died.
      *I didn’t get a chance to test drive it because of this.
      *One front tire goes flat fast, one rear tire has a slow leak.
      *He is going to buy a battery before I look at it again on Friday so I can test drive it.
      What do you think is the issue? Is it the battery or fuel system?
      Do you have a way to verify what year this is with the ID number and serial number? Also, the ID number of the deck. I’ll upload pictures of the stickers.
      *He says his driveway has an incline so snow and ice would pool around his door opening so he got tired of his wheels spinning. He decided to pay for plow service. (Home is big and nice with a lot of land.) He also decided to get a zero-turn mower so that’s why this 416-8 wasn’t used since after winter ‘21/‘22.
      He’s asking $500.
    • Boyd
      By Boyd
      wheel horse garden tractor mower, rear discharge mowing deck & snow blower both in good condition and runs well. all the parts for the snow blower are with it.
    • odee61
      By odee61
      Will the PTO work from the 312 Hydro with a 12 hp Kohler onto the 416-8 Onan?  My PTO disc went today. Any help would be most appreciated.
