drewd
Start then no Start
Started on the 416-8 that I picked up two weekends ago (posted under tractors).  The PO thought it was the starter but that is turning fine.  I have been able to start the engine by jumping at the solenoid and it runs quite well for not being started in a year or more.  Seems really decent.  My issue is it may or may not crank with the key!  First thing to mention is the battery is charged. The night before last I turned key to start and it cranked but did not fire right off so I let up and hit it again.  This time it barely started to crank, then hit it again and nothing it just stopped trying (it acted like a dead battery from the first crank that gives you just a bit before getting worse on the second and nothing on the third try).  Last night gave it a squirt of WD 40 in the carb and plug then turned the key and cranked strong and started right up (as I mentioned the battery is charged but tonight it acted like it!) .  Then I let it run a bit to warm up going from slow idle to full throttle then back down.  Shut it off with key waited a minute and NOTHING!  Let it cool down to where the muffler was cool to the touch and still nothing.  Any idea where I should start?  Thanks!!
With any electrical problem the first step should be to clean and tighten ALL electrical connections including grounds, that will cure about 90 % of them.
I had exactly the same symptoms two weeks ago.  Turned out to be a bad connector on the solenoid.    A little vibration or temperature change would break the connection.   If I jumped the solenoid, I was bypassing the loose connector.   I almost spent money on a new solenoid before I decided to check all of the terminal clips.
   Good luck,   Jim
Just finished fixing a 312 with the same problem. Long story short, solenoid was bad. Checked all connections first to eliminate that as an issue.
Bench tested the bad solenoid and it would not give consistent OHM readings when energized. Replaced it and problem solved.:)
The ignition switch is not great.  I cleaned it the best I could but one of the terminals is a bit loose.  It turns and starts right up but you have to be gentle with the switch.  I ordered a new switch and wire connector and fuse holders as they looked worse for the wear.  Thanks for everyone's help!
:woohoo:             Hope that fixes it.
  • Similar Content
    • By chemist
      This is the tractor~1989 416-8 I grew up with so I want to get her back up and running.  I am not getting any juice, nothing lights on the dash and the voltage meter on dash.
      The battery is fully charged, I changed the fuses and relay, the ground cable is clean.
      I know last time someone tried to start they cranked for a long time and likely burned something out.... any ideas?
    • By drewd
      The 416-8 I picked up a few months ago takes the larger diameter wheel bearings in the front wheels. The parts list show two bearing options depending on the rims you have.  Mine unfortunately take the 107124 bearing that I can only find as new/old stock for $55.00+ each or $230 for 4 with shipping.  Has anyone found other bearings that can be used in these rims?
      Thanks!
    • By drewd
      I'm working on the 416-8 I picked up a few weeks ago.  I need to replace the front tires so went to pull the rims.  One rim came right off as it should but the other will not budge.  I have removed the grease fitting and been filling it with WD40 for several days.  I have WD40 coming out through the bearing pretty well now.  I found a piece of tubing that fit over the axle perfectly and with a piece of wood over it pounded on it a bit hoping to break it loose but it just doesn't budge. The wheel that is frozen to the axle does hold air.  My next thought was to repair the other tire and just put the cotter pin to give some room on the frozen one and drive it around a bit in hopes that it will free itself once warmed up some with to pressure of turning, etc.        Any ideas on getting this thing off??  Thanks!!
    • By drewd
      Finally I have a few pics from the 416-8 I picked up last weekend.  Only the seat pan is pitted so I think the original had been damaged.  I had written that the PO had thought the starter had issues but it does crank.  Issue is electrical! Think I will need to rewire a lot if not all.   Got it to crank a bit but it quit just when it was ready to come back to life!  Hope to short the switch so I can get it running so I can start in on it when time allows.   They were asking 750.00 but in the end I got it for 550.00 with a 42" deck, dozer blade and grader blade.
