Rob R
Kohler Courage Swap to Kohler Pro
Rob R
Hi folks Brewster Rob here, was gifted a Cub Cadet LTX 1040 in great shape other then a completely blown 19HP in-famous Kohler Courage SV590, today I acquired a 17HP Pro OHV CV490S in perfect running condition.... so I want to swap the engines. They have identical vertical shafts question is the electrical. The Courage had four wires coming from the engine red/green/white/purple, the Pro has 3 white, 1blk and 1 red.  I also have the alternator and regulator from the blown Courage.... might I be able to swap alternators???  I of course have the old Courage key switch I do NOT have the new engine key switch.........  Need help from the Red Square wizards and PLEASE think about the best result way to go here.... thank you in advance.
953 nut
Your best bet is to get a wiring diagram for the Cub and whatever the other engine came from. There is little or no standardization of colors from one maker to another.
You could bolt it down and start the engine and use a volt meter to see what each wire is producing.
gwest_ca
Here is a start. Click on the pictures
Garry
Rob R
Okay thanks going through the manuals as we speak.  Does anyone know if the alternators can be swapped, I have the rectifier from the old Courage engine and the harness.
The good Kohler Pro engine came off a Craftsman Tractor I do not have the model # of it was the basic Green hydro cheapo model. Would be super if I could then I could just plug and play to the old harness........
Rob R
Okay so did the swap and hope to complete it tomorrow. I had to do some minor side frame work (oil filter was hitting right side support). Spent hours comparing the Kohler Courage to the Kohler Pro electric wiring configuration 953 nut was correct all the wire colors were different so you just need to verify voltages and where they are going to (old to new) bottom-line had to remove from the nine pin Molex connector the two AC wires (that were previously used for the lights) and that was it. My thanks to Ed Stoller who helped verify that was all that needed to be changed.
Engine cranked and I had spark, also the fluid solenoid was operating. Tomorrow will do the final bolt down of the engine, re-install the fuel tank and Drive Pulley and see if she drives and charges.....
Rob R
Done deal, had to lengthen the muffler pipe from the engine 2 inches, cleaned the mounting holes (to make a good ground, the existing fuel tank, and accelerator cable fit perfectly, installed the bottom double pulley, connected the molex plug, put the battery in and she started right up took her for a spin NO issues runs great.... tomorrow will
install the mower deck and see if we can cut some grass!  Thanks once again for the help......
Edited by Rob R
Aldon
Where are the obligatory pics??
:think:
Rob R
Okay Aldon you asked for it here's the pics, I am very pleased with the results was worth the efforts, many thanks for the help rec'd.
Aldon
Looks like it turned out great!
  • Similar Content
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • Rick3478
      By Rick3478
      For Sale NOS M12S Short Block, still in the original box.  I bought it pre-emptively when Kohler was phasing out the Magnums.  Thought I would have it on hand if one of mine needed it, or maybe I would find a tractor with a busted rod for cheap.  Neither of those things happened, the darn things just keep running.
      Part number 77 522 35, probably built in late '05, it's the combination replacement kit Kohler made to fit WheelHorse or Gravely, machined to bolt directly into the Gravely transaxle, but also has spacers to mount WheelHorse PTO clutch/brake.  Also has a bunch of gaskets and seals packed with it, probably all you need to install it.
      And it's heavy, so it's not practical for me to ship.  Buyer arrange to pick up near Elida OH, I can lift it about knee high to help load.
      Asking $800 or might consider trade for a good center mount grader blade.
    • mcfarmall
      By mcfarmall
      Tractor features Kohler 16hp cast iron engine, gently used 42" deck, concrete wheel weights, tire chains, new Chinesium carburetor, fuel lines and filter, new air filter, 2 new fwd/rev cams.  A starter,  some new gaskets, and miscellaneous parts.  New drive belt and all the belt idler assemblies.  Engine runs but smokes.  Great restoration candidate or a spare engine for you pullers out there.  Call, text or email for a private showing.   No offers considered unless made in person.  Buyer responsible for transportation.  Many more pictures to send to interested persons.
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
