hbrooks49 12 #1 Posted August 24, 2017 (edited) Sorry for the lousy picture - finally got the right angle. I have a C-105 and was mowing the lawn yesterday. It began to lose a bit of power and seemed to almost skip once in awhile. When I pulled it into the garage it stalled out at about 1/2 throttle. I checked and the gas looked low but not out.. I checked the throttle linkage and noticed that the screw shown in the picture below is loose - it attaches to nothing. The throttle cable (fed from the left hand side - seated) is shown above the screw and attaches to the plate with a "z" bend. In all honesty I can't figure out what the screw would be for since it is way above the pivot point... unless it used to be part of a clamp for a cable without the "z" bend. If the screw is doing nothing I will work on looking at the old fuel lines (need to get new hose before I start messing with it - it is the original hose - enough said... Thoughts would be appreciated - getting too old to use the regular mower again. Thanks Edited August 25, 2017 by hbrooks49 New picture Share this post Link to post Share on other sites
hbrooks49 12 #2 Posted August 25, 2017 opefully with the new picture I can get an answer - if not will start by replacing the fuel line tomorrow. Share this post Link to post Share on other sites
pacer 3,159 #3 Posted August 26, 2017 I have had engines where that screw - or similar - was used to hold/clamp the throttle wire instead of the Z bend, if nothing is connected to it then possibly? the throttle cable was replaced at some point and the new one used the Z bend??? Share this post Link to post Share on other sites
hbrooks49 12 #4 Posted August 26, 2017 Thanks, that was my thought so I will proceed on the premise that when the fuel got low it probably swallowed some of the stuff in the bottom of the tank. The more I think about it that makes sense - I had a Model "A" Ford that would fill it's sediment bowl if the tank got too low. Share this post Link to post Share on other sites
