Team70R
Gt14 package deal to good to true??
Found a gt14 that needs hydro pump rebuilt along with a 48" deck, 3 point hitch, tiller, and rear mount generator for $500 and no one has jumped on the deal.. what am I missing here? :o:think:
Hydro pump rebuild can be expensive. That would be my guess.
The tiller only fits GT 14
I'd be quite interested but I'd gather more info on the hydro repair.  Lots of info on this site too!
The power unit on the gt-14 is sundstrand 90-2062.  I have rebuilt several of these and MAY be able to service this one, depending on its condition.
for further etails, send me an off-site email....  my email address is:
daveoman@windstream.net
You can use a hydro unit from an Electro or Charger with a few simple steps to change out the drive gear. Too far away for me or I would jump on it.
It's for sale on the "Garden Tractor Junkies" Facebook page. Located in noblesville Indiana. Thanks for your input Dave! And the pulley I got off of you worked perfect! I'm gonna have to think on this one and see. Gotta make some room in the stable if I wanna bring anything else home!
  • Like 3
  • Confused 1
A hydro rebuild sometimes only means the springs in the acceleration valve. That's not bad at all.
$500 seems like a great price. If that photo is accurate, I don't see how you could lose money, even if you find it's a dog, you could part out everything and probably make money.
  • Like 3
I just feel like there's something fishy! It's been for sale since may at that price
   It looks like you are only a half hour away. Just go look at it.  Start it and run it and then ask the GT experts here about it
 It better start and run for the asking price.  I would not hold my breath, because it has been around for a while
 If it does not because it "needs battery", then yeah, may be fishy.     Sellers often say they have a great tractor, but YOU can fix it easily when it does not run. That is when they are hiding something
That is why I bring a battery and jumper cables every time i look at one. Take a ignition key as well
 Maybe all that is wrong with it is the screw is in the "tow' position, Maybe the drive key is not in the transmission pulley It is possible the seller inherited it and knows nothing about the tractor and if so, you just stole it
Good luck.
  • Like 4
  • Excellent 1
Well, yeah, it's old, and it isn't Attach-o-Matic, so it's hard to find implements, or parts. For instance, the springs I needed to fix my hydro, I had to buy from a guy that had a special run made.
But, there is only so much that can be broken on it, and every part of it is sellable on here or ebay for fair prices. For instance, the three point hitch is a very popular item that people seem to like for it. Probably worth at least $200 complete. That seat looks pretty good. If no tears, that is worth something. I do notice the particularly bad paint job on the wheels. So you may get out there and see it's a crude paint job, over existing rust. Best thing to do is just see if it runs, find out what the issue with the transmission is. If it runs, but has trouble going in one direction, like forward, but goes backwards fine and the rest of the hydraulics work, that is an easy transmission fix, just the acceleration valve spring.
  • Excellent 1
While you are wishy/washy ing around, someone is gonna grab this and you'll have your answer.  Surely, you've (and I) hasve done much worse things worse with $500 bux...
Edited by daveoman1966
  • Like 3
I've tried contacting the seller two different methods with no reply. Guess it was too good to be true
Your story doesn't quite add up to me.
To begin with, Wheel Horse Junkies is not a sales or "what's it worth" page. So mentioning that doesn't hold much water for me.
Anything that gets posted there for sale gets taken down pretty quickly.
You don't cite a link or a post.........and I can't find it.......even on the sister site which allows sale postings, Wheel Horse Garden Tractors and Parts.
I've owned a first year (1969) 1-7741 GT 14 since about 1980.
I follow this stuff pretty closely and there are GT 14s for sale here in northern Indiana, but the one you mention is an unknown to me.
I need more relevant info in the form of an actual listing to give you my 2 cents.
Regards,
Steve
You can switch the GT14 to newer attach-a-matic pretty easily. Front and mid mount brackets.
Regards,
Steve
Here is a screen shot of the listing. It's also posted in the Facebook "marketplace" if you change your area to Noblesville you should be able to find it quickly! Still no reply from seller
No luck here.
You are working from a phone.
I work from a keyboard and a PC.
I can find NOTHING about Garden Tractor Junkies on FB.
C'est la vie.....
7 minutes ago, ztnoo said:
No luck here.
C'est la vie.....
Wow that's odd! Maybe that's why no one has bought it!! It's a secret group!!
Edited by Team70R
  • Haha 1
Provide the actual link to the FB group and I'll check it out.
Facebook.com/groups/119400231742340
 Try this and see but it says only members can see group
Edited by Team70R
Sorry.................nada........................nothing.
I have no idea what you are looking at, but it doesn't appear to be very accessible.
Someone has it set as a secret group for some reason. I'm not sure how to join honestly
How did you even see the listing to begin with then?
  • Similar Content
    • By Rob R
      Complete Heavy Duty Wheel Horse Three Point Hitch Attacment with class one (1) drawbar. This Attachment is relatively easy to install; remove shifter panel, seat and set ratchet panel and bolt this in. Unit comes with EVERYTHING you need to install on a 1969>72 GT14. Includes: Rock Shaft, Rear Axle Bracket, Drawbar, 2" Trailer adapter, Stainless Steel side chain adjusters. Center adjustable Link. Everything is Heavy Duty. All bolts, pins and clips are included. Brewster,  NY Pick-up; Cell 914-282-0050
    • By Rob R
      Sooo about three months ago I had a friend of a friend pass to me the most needy Wheel Horse GT14 Tractor I had ever seen, it was completely taken apart every single part had rust and two coats on oil paint one blue and one yellow. parts were missing and of course there was no labeling of parts or assembly there-of. All wiring, gauges, rectifiers were removed and non existent….. still the machine was calling to me to try and do the almost impossible...… My thanks to Aldon for parts and support and Kyle for Technical help and shoulder to cry on. ….  The only saving grace of the entire project is that the engine and tranny were indeed still good...… in fact the only remaining issue I have on the machine is that I cannot free-up the relief valve so that I can move the machine w/o power..... I think this might be stuck forever … but not the end of the world.
    • By ChaplainManny
      Hi. I'm Chaplain Manny. I was wondering if you supply the decals for the gt14, the kohler k321 engine?
      If you do, could you give me a quote, and tell me how long is the turn around?
      Thank you.
    • By swisstrac
      Would someone   know if it is possible to remove the gas tank without taking off the grille    in order to to work on  fuel pump and carb on the GT14  1970 model with full grille   thanks  for your hep//Ray
