Ive been trying to change the headlight bulbs on my 312-8. but i cant seem to get the glass cover off. So are these bulbs change able? And is there a reason for the headlights to not function if they are getting current?
- Tractorboy
I changed the bulbs in my 520H a few months ago. There were no glass covers.
Post a pic of what your looking at.
image.png.a7508f3bb80fc84e1a34ab60df177393.pngJust undo the clips at the 3 O'clock position and they pop right out
Edited by BaySide1
  • Excellent 1
Yes, the bulb is bad.They are a sealed beam headlamp, take the old one to an auto parts store and they can fix you up.
  • Like 3
OR ..... the bulbs have a poor ground.   If the ground wire for the bulb is attached to the hood there could be no ground.  When the ground is the hood, the circuit must pass thru the hood hinge to get back to the battery.  That's a bad connection.  There needs to be a jumper wire from the hood to the tractor frame.  If you're using a test light connect the alligator clip to the ground side of the bulb and probe the (+) side of the bulb.  Got light?  If not you'll need to fix the ground.  If the test light came on you'll need bulbs!
Edited by N3PUY
  • Like 6
I got the headlights off the hood. there is a glass lenses covering in front of the bulbs. i was wonder as how to a individual would go about removing this glass lenses? Yes i have that kind of ground, but it worked fine before.
The glass lens IS the bulb... the element inside is not a serviceable part. Take it to the auto parts store and get the replacement... they're cheap.... well I see you're in CT... so perhaps not quite so cheap! ;):lol:
  • Like 7
This is what a sealed beam headlight looks like. It is a one piece replaceable unit. You don't remove "the bulb", it is a sealed unit.
Image result for sealed beam headlights
  • Like 5
  • Excellent 1
X-2 ^^
And don't bother replacing them with the LED's that are an exact replacement .
I did on the snowblower that's at my mom's house and couldn't be more disappointed ,
They advertise that it's equal to a 50 W halogen .
Bullllll !
it looks like a candle and will probably outlive ME :blink:
https://www.amazon.com/gp/product/B00SFCJ01A/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
  • Thanks 1
  • Sad 1
The easiest way to test those is to connect the terminals of the sealed beam to a 12 volt battery with a jumper wire.
Edited by TDF5G
  • Like 3
  • Excellent 1
If there is not a bad ground and you are getting power to them yes. If you have a multimeeter you can ohm them out to make sure they are not bad.
Is that right @Digger 66 ? I was groining to pull the trigger on a pair of them for the 520. Keep the amp drawn down so I could run those and the hi-test cab lights. Nice to know they're not worth a hoot. Looks like they good reviews?
  • Thanks 1
I just felt a lot older, these young wippersnappers don't know about sealed beam headlights. Now we have the plastic junk that fogs and costs a fortune to replace.
  • Haha 1
I don't care for it . It's white , yes . But as for illuminating the work area ? It gets a 3 out of 10 .
  • Similar Content
    • By r1jakecfd
      Hi Guys,
      I know my voltage regulator is bad on my Onan P220 and was wondering if anyone has an opinion on a replacement, OEM or aftermarket?
      Also, I checked my stator leads for AC Voltage and got about 25 volts at 3600 rpm on each. Is this OK? I know it says in the 40’s.
      Thanks guys
    • By lodestonefarm
      I went out to use my 520H with blower this evening and it won't start.  I used this machine a few days ago (for the first time this winter).  The battery has been on a trickle charge so I don't think that's the problem.  It's done this before where it won't start, won't start, and then starts.  Usually that is in cold weather and after I've previously used it to blow snow.  I don't have a heated garage so I think it might have some ice somewhere that was introduced as water the last time I blew snow.
      Here's what it's currently doing.  When I turn the Ignition to 'On' the red warning lights and the dashs light all come on.  When I turn the key to start position I get a single 'Click' and nothing more.  I tried jumping it from a hot battery just to rule out a bad battery.  Same behavior.  Following some of the other threads about 520s with trouble starting, I pulled the blue wire off the starter solenoid.  If I run a jumper wire from the (+) side of the battery directly to the solenoid I get the same behavior (regardless of key being in on or off position)- small spark where my jumper wire is touching the battery terminal and a single click.
      I'm unsure what this means about the solenoid and if that, in any way tests, the starter.  Could it be that my starter is bad/frozen?  I tried using a heat lamp to warm up that area, but in this weather (and my garage, which is really just a tarp shed) that just isn't going to work.
      I've downloaded the demystification guide and started looking at it but I'm hoping someone might have some suggestions.  Snow is falling and I'm not making much headway on this.
      Thanks
    • By dirtyhead
      312-8 has no power leaving relay to solenoid,If I use the switched feed to the relay on the solenoid it starts but I have no safety devices.The low oil switch wires have been joined where they leave the multiplug as one of them broke right at the switch too close to solder.The clutch and pto switches are good.When I turn the key the relay makes a faint click,when I turn it with the clutch depressed the solenoid joins in with a half hearted click.Could the low oil level wires being joined be contributing to alow voltage at the solenoid signal wire?Anyone got any ideas?
    • By Jeff-C175
      Detailed wiring from the Demystification Guide #492-4509
      4 pages 112.52KB
      p7-67 to p7-70
      Onan powered
      1989 416-8 model 31-16O801
    • By RT WH520
      Need help...I have a 520H and I have not worked on small engines other than basic maint.
      My P220 is showing that it is not charging the battery. I got a new battery and after using it a bit, it will not start. I know the basics of looking for wires shorting and other basic.
      I have the manual also. Should I start with the rectifier regulator. It is cheap enough.
      Any thoughts and suggestions appreciated!!!
