Tractor boy
Preferred snow plow blade edge?
Tractor boy
I need a new cutting edge for my plow, so i was wonder what type would work for my millings drive way? Also what is the difference between rubber and steel? And any tips for getting the old one off? The edge is so worn down that it started wearing on the moldboard and has started to wear the edge bolts down.
- Tractorboy
ohiofarmer
 Could you flip the edge upside down? I have one just about worn out that I really will not use much, but i am considering doing just that.  You may have to weld some tabs on the worn edge to get it to stabilize against the blade body
Tractor boy
No the edge is completly shot and the holes might be too.
WVHillbilly520H
With the asphalt millings I would suggest using a steel edge again (my dad and myself have used car/truck leaf springs welded to the original edge last pic rear grader blade) but also investing in a set of skid shoes(not that hard to make as I have made some the raw metal in the pics vs the black T/WH which can still be bought from Toro) so yo can keep that cutting edge up 1/4"-1/2" above the millings surface when level ,reducing edge wear and surface media removal, Jeff.
Sarge
There's a couple folks selling 1055HC in 42" on the popular auction site - no holes but the stuff can be drilled with cobalt bits . For the price , it should last the life of the blade unless you're constantly using it on concrete . I replaced the edge on the big D's 56" with the stuff in 1/2" thick - it comes pre-beveled nicely and will cut nearly anything it hits easily .
Sarge
Tractor boy
I think ill probably just use some flat stock with new holes. (i have some laying around) also any light sugesstions for my homemade weight bar?
96WS6TA
my drive has a few cracks so I got an old tire cut to length drilled holes and mounted as a blade  works awesome
  • Similar Content
    • Mattgray
      By Mattgray
      I am looking for a snow plow in the Western NC area, might be a long shot but iv checked marketplace and craigslist. No luck. if anyone has one or knows where I could get one. I believe I need a long frame one for my tractor. Thank you!! sorry if I posted this in the wrong spot. One year after owning my wheel horse and still running strong!
    • Marc M.
      By Marc M.
      Hi guys I'm new to the wheelhorse world and i recently picked up a for 416-H and I'm looking to buy/install a plow put on it. I have found one on craigslist but I can't tell if it will work on my tractor or not, it is a wheelhorse plow though. Can somebody please send a photo or even a video of how to hook up a plow to a 416 or equivalent tractor?
      Attached is my tractor and the plow I'm looking at. Will it fix and what's it missing ?!
    • Red308
      By Red308
      Hello! I purchased a WH 308-8 with a snow blade and a mower deck. I have the manuals for the mower deck and the tractor but I have absolutely nothing on the plow. It has a 42" blade and I think the frame is 56" from the end to the pivot point. I have found lots of information on similar blades but I have been unable to figure out exactly what model mine is. I am asking simply because I am curious. Thanks in advance!
      P.S. It doesn't work real well on the 308-8 as I currently have it. I think I might be missing a piece.
