Mt Zion 520H 43 #1 Posted August 8, 2017 The ones on it are all plastic and wobble on it when off ground. Measured them at 5 3/4". Figure they might not be the ones for it and extra height from larger wheels would be beneficial seeing as i have loads of lumps and bumps on the land. What do you guys use and like? Share this post Link to post Share on other sites
WVHillbilly520H 10,369 #2 Posted August 8, 2017 I use the original red steel centered wheels can be found on eBay as a kit with the axle bolts and also with the anti-scalp rollers as well, hope this helps, Jeff. 1 Share this post Link to post Share on other sites
Mt Zion 520H 43 #3 Posted August 8, 2017 Thanks brother. Was thinking maybe a tad larger diameter? The deck at highest hole has the back of blade at about 3" off ground. When i put new blades other day; noticed there's spindles, thick washers, blades, thin washers and then nuts. Spindle or something in it.. Opposite the exit seems to be bent because the height changes when i spin it. Using exit side and center the height remains about 3" off. With wheels dipping into holes and all.. I'm not really able to get a taller cut for healthier grass to grow. Share this post Link to post Share on other sites
Aldon 4,826 #4 Posted August 8, 2017 Just be sure that with larger rear wheels when you have the deck in the most high cutting setting that the center pulley does not impact with the deck hanger lift bar. You could grind off the grease fitting and damage the spindle. I've seen this on a few decks. Share this post Link to post Share on other sites
daveoman1966 3,562 #5 Posted August 8, 2017 I have a pair of ALL PLASTIC / NYLON (?) deck wheels that are 8" dia x 2" wide. OEM wheels are 6" diameter so these, at 8" dia will raise the deck by 1" and should give clearance for yard knobs... NOTE...these have separate replaceable steel bearings.... email to me at: daveoman@windstream.net Share this post Link to post Share on other sites
cleat 4,895 #6 Posted August 8, 2017 1 hour ago, Mt Zion 520H said: Thanks brother. Was thinking maybe a tad larger diameter? The deck at highest hole has the back of blade at about 3" off ground. When i put new blades other day; noticed there's spindles, thick washers, blades, thin washers and then nuts. Spindle or something in it.. Opposite the exit seems to be bent because the height changes when i spin it. Using exit side and center the height remains about 3" off. With wheels dipping into holes and all.. I'm not really able to get a taller cut for healthier grass to grow. Starting at the spindle, there should be a thin washer, blade, thick washer then the nut. If you put the thick washer at the spindle, you will have a slightly lower cut. Cleat 7 minutes ago, daveoman1966 said: I have a pair of ALL PLASTIC / NYLON (?) deck wheels that are 8" dia x 2" wide. OEM wheels are 6" diameter so these, at 8" dia will raise the deck by 1" and should give clearance for yard knobs... NOTE...these have separate replaceable steel bearings.... email to me at: daveoman@windstream.net Ball bearings are always an upgrade. The 60" deck comes with ball bearing wheels. Cleat Share this post Link to post Share on other sites
Mt Zion 520H 43 #7 Posted August 9, 2017 (edited) 4 hours ago, Aldon said: Just be sure that with larger rear wheels when you have the deck in the most high cutting setting that the center pulley does not impact with the deck hanger lift bar. You could grind off the grease fitting and damage the spindle. I've seen this on a few decks. Thanks for the tip brother. I will see if i can emulate larger wheels by putting an inch of something under rear wheels and see if it hits before moving fwd. 3 hours ago, daveoman1966 said: I have a pair of ALL PLASTIC / NYLON (?) deck wheels that are 8" dia x 2" wide. OEM wheels are 6" diameter so these, at 8" dia will raise the deck by 1" and should give clearance for yard knobs... NOTE...these have separate replaceable steel bearings.... email to me at: daveoman@windstream.net Email sent brother. cleat... Thanks for the washer, blade, thicker washer order brother. Seems they were put in the wrong way. I'll have to fix that next time around. Edited August 9, 2017 by Mt Zion 520H 1 Share this post Link to post Share on other sites
Mt Zion 520H 43 #8 Posted August 9, 2017 Anyone ever use those from tractor supply with the grease fittings? Share this post Link to post Share on other sites
WVHillbilly520H 10,369 #9 Posted August 9, 2017 The factory originals have a grease fitting, but are only bronze bushed but my first set on the one I bought brand new lasted 14-15 years, Jeff. Share this post Link to post Share on other sites
