876wheelhorse
What 3 speeds will interchange?
876wheelhorse
I've got a 502 that the reverse has some noise to it. I've got a chance to buy a 855 with a 3 speed in it... will this work? I've heard something with the brake tab...
876wheelhorse
Needing a 3 speed for my 502 which will interchange.  I've got a 855 will that work?
Racinbob
It will be a direct bolt in. The 5049 in the 855 has updated shift rails over the 5025 in the 502. :)
Racinbob
Any thoughts about opening the 5025 up and fixing it? It's really pretty simple and you can get all the help you need right here. :)
stevasaurus
The transmissions that will bolt right in with no changes or fabrications...#5007, #5025(your 502), #5046, #5048, #5049 (your 855) and the #5053.  Yes that trans will bolt right in.  :)  What is wrong with the trans on the 502?  Don't you dare throw it out...they are all fixable.
