Thor27
2 C-85s followed me home today
Thor27
Craigslist find that just happened to fall together today.  The first tractor is pretty straight but appears to have not run in the last decade... The second is pounded, prior owner replaced the kohler with an 8 horse briggs, and the seat pan with a metal one that did not have a filler hole in the right place (268H), so he sawed the neck off the gas tank and duck taped on it's replacement". Over all it's a mess, but that loader is pretty darn nice and it seems to work well, but tractor doesn't run well enough to give it a good work out yet. The only leak is it seems to be some weeping at the drain hole on the tank.  I'll need to build a weight box for it, but over all pretty excited as I've looked a long time for a loader.
c85.jpg.79bfb6c8832112cba645b71019f282d7.jpg598647915a331_c852.jpg.cfec5584d1747be98a4d59a1b90cd351.jpgc854.jpg.f35ffa8c8562e969b7af3bf86a58a3c9.jpgc853.jpg.4bd73b3a70b70c7e4288b27121218227.jpg
Edited by Thor27
  • Like 8
gwest_ca
Nice
Garry
Thor27
Thank you Garry!
elcamino/wheelhorse
@Thor27 Nice haul , was the tiller part of the package? Is the gas tank attached to the cross bar on the Fel ? Like the weight rack on the back. Looks like you have some work to do , but you should have a great loader in no time.
953 nut
:text-coolphotos:        That fuel tank is shade tree engineering gone wrong! :-o  Looks like the loader is complete and ready to rock and role. :handgestures-thumbupright:
Thor27
Thanks Jim, Yes on the tiller, the one with the loader has the pulleys and rock shaft for it too. That is the gravity fed gas tank, Cringed a bit adding gas when it was on a battery charger! That weight rack stuck in the ground like an anchor when I tried to unload it.... it has to go!
Thor27
I wish I would have remembered to take a picture, but the gentleman that sold me this had the coolest walk behind crawler tractor, I think it was an old vaughn. It had a big Wisconsin engine and metal tracks, but he wouldn't part with it.
TDF5G
:text-yeahthat:    :-o on the fuel tank too!
Retired Wrencher
Thor27  Looks like those two will keep you busy for a while. I hope the loader works for you. Enjoy the project.
Thor27
Thank you Gary!  Plan is to freshen up the loader and put it on my C-105. I was able to play with it a bit before I tore it apart, I'm really going to enjoy this!
Surprisingly the loader itself is in pretty good condition, the sub frame has been butchered badly, and the bucket has been cut down, but all in all it's a great start.
When there is some progress I'll put a thread in restorations. The C-85 it was on is just plane worn out, but I plan to redo the other one eventually.
Edited by Thor27
  • Similar Content
    • PWL216
      By PWL216
      About a year ago I bought a C-121 auto with the intention of using it as my go-to mower. Shortly thereafter I got a great deal on a low hour 314-8.  It ran perfect and had several attachments - it became my new go-to mower.  So, I decided to repurpose the 121 to be a front end loader. After purchasing the build plans from P.F Engineering (which are excellent), I realized I couldn’t build it for less than $2k in material. I decided to look for a used one and found a Thompson TC10 local to me, mounted on an “end of life” 1077, for $1,000.  The loader swap itself was pretty straight forward. The only modifications needed were drilling a couple of mounting holes in the tractor frame, grinding away a little of the loader top frame so the hood opened/closed and welding in a new hydraulic pump mount. I have a few things to button up still and the bucket itself needs attention but it’s fully functional. I also bought a pair of clamp-on pallet forks.
      I also did a “refresh” of the 121. The total project cost is shown below. Roughly $2,300, with just the FEL itself being around $1,300.
      Tractor
      C-121 Auto $500
      Solid engine mounts $50
      Front End Loader
      Johnson 10TC $1,000
      Hydraulic fluid $35
      Spare hydraulic hose $40
      Ignition
      Battery $35
      Battery cables $20
      Points & Condenser $20
      Fuel
      Carb & Gasket $65
      Electric fuel pump $60 (later removed)
      Air filter $10
      Fuel filter $15
      Fuel line $10
      Spark plug $5
      Decals and Paint
      Decals $115
      Paint $30
      Lights
      Headlight Lens $45
      LED Headlights $25
      Rear lights $25
      Misc $200
    • PWL216
      By PWL216
      Howdy. I recently purchased a non-running 1277 with a Johnson 10 Loader from a fellow RS member. I bought it for the loader - to put on my C121, then I figured I’d just get rid of the 1277. Now I’m wondering if I should try and get it running and leave the loader on it. The motor turns by hand. I’ve tinkered with motors but never much more than the basics. The battery that’s in it is labeled 2017, so it probably was in use then.  What’s the easiest option, swap the loader or try and get it running? What would you do? Thanks!
    • Workin_Horses
      By Workin_Horses
      Kwikway loader that is currently on my 520H (Tractor not for Sale) with custom quick attach for switching between bucket and custom made pallet forks. The sub-frame allows it to fit some other models as well.
      I designed and built the pallet forks and quick attach setup several years ago.  Just remove 1 pin on each side to switch implements.
      Forks are adjustable and removable.  2" box receiver built into fork rack
      Also included is a custom rear axle suitcase weight bracket that holds up to 6 of the 43lb weights
      You can bring a tractor and we can install it on your tractor here or bring a trailer and I can load onto a trailer for you.
      Pictured TRACTOR and WEIGHTS NOT for Sale.
    • mmmmmdonuts
      By mmmmmdonuts
      With a front end loader for these tractors how important is a ladder type subframe? Does the cross piece in the front have to connect where the towers are? Can the frame where the towers are just mount to the frame and go back to the transmission or is that cross piece critical where the towers mount? Could it be set further back with the same effect or would it not be the same? I know it is important to go back to the transmission so if you hit something you don't snap the frame, but how critical are the cross members?
    • elliot ness
      By elliot ness
      I picked this jewel up yesterday at a John Deere dealer, it's a 224 case ,but it has a 16hp Onan on it, and someone put Power steering on it. It has a few leaks, but runs great. even has a joy stick.
