W/H JUNKY 43 #1 Posted August 4, 2017 Hi everyone when hooking up the ammeter on my 701 does the A wire from the voltage Reg go to the + or - terminal of the ammeter. Also the starter and batter wire what terminal do they go to. I have had the gen/ starter tested and it is work as it should but the gauge is in the neg when running. Thank in advance. Share this post Link to post Share on other sites
WHX?? 46,701 #2 Posted August 4, 2017 Here's the manual with a wiring diagram in it. The positive post of the ammeter (if labeled) should go to the + post on the battery and be tied on with the + to the ignition switch. If you know the S/G I& regulator is good and the meter reads backwards just flip the wires around keeping the + to the switch with the + on the meter. If that don't do it there's no hope and I'll just have to come get the tractor from you! Share this post Link to post Share on other sites
W/H JUNKY 43 #3 Posted August 4, 2017 Thank you WHX11 If all goes well we will see you in Porage Wi again next year Share this post Link to post Share on other sites
