kjcspencer
what year and model is my wheel horse
kjcspencer
Newbie here, I have a C-165 and am looking for information on exactly what I have as well as any other information available.  There is an "ID Number" located on tag under the dash.  It reads 1116K801 with a space and then Z8603. The engine is Kohler model K341, Spec 71179, serial 2229505963.  Have no history as it came with a place I purchased.  Mower deck is pretty rotted out & will need to be replaced at some point.
 It runs well & my thoughts are to just use it but part of me wants to fix it up and then use it some more.
Sparky
Heres what ya have...
     11-16K801 1984 C Series Garden Tractor C-165 8-Speed Kohler K341AS-71311A 16 Wheel Horse 103916.
 :WRS:
 Mike.....
KC9KAS
@kjcspencer :text-welcomeconfetti: to :rs: from another Hoosier!
Retired Wrencher
:WRS: Enjoy your C-165. These are great working tractors. You can do a lot with these lots of power there. Just take care of it. Print out all the manuals for it. There is a great Manuals section here.This will make it easy to keep all the PM`s  up to date.
Edited by Retierd Wrencher
SylvanLakeWH
Love the Black Hood :wh:'s!!!
gwest_ca
Not that it matters but the Z8603 tractor serial number will be 28603.
The 71179 spec number is not original to the tractor but is a service replacement engine Kohler made in 1992.
Should give you many many years of service.
Garry
kjcspencer
Awesome response, thanks to all!  Thanks Garry for the information;  taking a very close look at ID tag on tractor does show it is a "2" & not a Z,  Also good to know about engine age as well.  The ID tag on it does look a little different than a few other Kohler Engine tags I saw on this site.  So much good information to be found here, I will take some time, get manuals downloaded, and do my research.  This is going to be a little work but fun too.
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
