jkolasa 7 #1 Posted July 31, 2017 Tore into my D 160 rear end to replace axle seals. Found axle bearings were bad. Split trans and replaced all bearings. Removed hydro motor from trans case in process and took that partially apart. got everything back together and when I push my motion control lever forward I go backwards and vise versa. I assume the problem in I didnt mark something i should have and have it opposite of what its supposed to be. Any thoughts? Share this post Link to post Share on other sites
pfrederi 17,147 #2 Posted July 31, 2017 Download the Sundstrand manual from the manuals section here. You probably put the hydro motor cover on upside down. 1 Share this post Link to post Share on other sites
jkolasa 7 #3 Posted August 1, 2017 Lol, after i made this post i did just that, sorry for the waste of time, call it a pop quiz if you will 4 Share this post Link to post Share on other sites
pacer 3,159 #4 Posted August 1, 2017 Heh! I'm ashamed to say I did the same thing!!! ---- and KNEW BETTER!! 1 Share this post Link to post Share on other sites
