carlosking450 149 #1 Posted July 27, 2017 Hello, I would like to know what model of gearbox is my Wheel Horse 702, is there a manual with the cutting? 1 Share this post Link to post Share on other sites
KC9KAS 4,741 #2 Posted July 27, 2017 702....7 hp Kohler....not sure on the 0, but the 2 is 1962. Share this post Link to post Share on other sites
953 nut 51,656 #3 Posted July 27, 2017 5025 gear box. 1 Share this post Link to post Share on other sites
carlosking450 149 #4 Posted July 28, 2017 Is there a manual with the parts list for this gearbox? Thanks 1 Share this post Link to post Share on other sites
Lane Ranger 10,494 #5 Posted July 28, 2017 (edited) Carlos: 702 Manual is right here on Red Square: I am in the process of rebuilding a 702 right now ! Edited July 28, 2017 by Lane Ranger 3 Share this post Link to post Share on other sites
carlosking450 149 #6 Posted July 28, 2017 OThanks Lane, ohhhhh very nice I also have my 702 completely dismantled, I'm going to repair the gearbox and start riding, you have to see how small these tractors are and how much work they have As soon as I have time I will continue to put photos of my restoration in the section "restorations" a greeting from Spain. By the way is there an economic distributor for the replacement of bearings and seals for the gearbox of the 702? Thanks from Spain 1 Share this post Link to post Share on other sites
stevasaurus 22,229 #7 Posted July 28, 2017 check out this link Carlos...you want PDF #2. Also, check out this thread. Share this post Link to post Share on other sites
carlosking450 149 #8 Posted July 28, 2017 I saw it Stevasaurus thank you very much,I also saw a video of you explaining the repair step by step, thanks I have one more doubt, my gearbox is a 5025, all are the same or being the same change can vary the diameter of the axles? Share this post Link to post Share on other sites
stevasaurus 22,229 #9 Posted July 29, 2017 No. If I am understanding your question...if you have a case that has 1" axles, then you need to have 1" axles in it. 1 1/8" axles are not an option. I believe the opposite is true also. I'm sure some body will come up with a way to do it, but it would require more then it is worth. Just get a different trans if you want the 1 1/8" axles. I'm thinking if you want new bearings and seals for that #5025 transmission, send a PM to @wheelhorseman...he is a vendor here on Red Square. 1 Share this post Link to post Share on other sites
Farmer boy 3 #10 Posted November 15, 2021 My 702 wheel horse transmission is unresponsive it doesn’t move when I put it in gear the gears are really loose any body have an idea why Share this post Link to post Share on other sites
AMC RULES 36,945 #11 Posted November 15, 2021 https://wheelhorsepartsandmore.com/shop-now/ Share this post Link to post Share on other sites
stevasaurus 22,229 #12 Posted November 15, 2021 @Farmer boy Please start a New Thread in the "Transmission Section". Please explain a little more about your issue. Like, is it your shifter that is loose. Add as much information as you can. Share this post Link to post Share on other sites
