Hoffertot
86-87 42" center pulley assembly
Hoffertot
Hello everyone,
I recently had some issues with the middle blade cutting grass while I was mowing. I decided to take the mower deck off. I believe I have found the problem, and that would be a missing bushing or spacer, but I can't seem to find it on any of the assembly documents I have. Could anyone help me verify if my assumptions are correct, or assist me if you see something else that is wrong? Here are some pictures to hopefully better show what I am referring to. The mower model I own is a 86 Wheel Horse 312-8 manual mower.
The first image is the mower deck itself, presumably a 0542ms04 ( this is the 42" deck). No identifiers on the actual deck.
The second image shows the pulley being referenced and the mount in which is suppose to attach to.
The third image is hard to see, but the actual spindle shaft sticks up higher that the pulley so tightening down the top bolt does not actually secure the pulley in place. This causes the pulley to spin with the belt, but the pulley is loose with respect to the spindle shaft.
The fourth image is the assembly drawing I have been referencing to troubleshoot the issue.
Any help or guidance would be appreciated. And this is my first post in the forums so if this has been answered before, or this post should be moved, please let me know.
Thanks!
gwest_ca
Suspect the spindle assemblies are like this one or older
The spindle and pulley are known as the double-D series with a 5/8" x 3/4" hole.
The mower blade center hole should be the same.
Garry
N3PUY
How is it possible for the pulley to spin on the shaft if both are "double D" ?
I'm guessing the pulley "double D" is worn into a circle.  I think I talked to a guy up the road last year that had the same problem.
A new pulley is required.  :think:
Hoffertot
Thanks for the quick responses. The other 2 pulleys are both double D onto the spindle shaft. This double pulley is not a double D shape, and this is why I wan wondering if I was missing an insert or adapter to mount to this pulley. The thickness of the part that slides over the shaft(shown in the picture below) is nearly an inch thick, I can't imagine it would spin and round the D shaft like that. I guess there is potential that it had the wrong pulley assembly installed on it when I purchased the unit.
There is a lot of slop between the shaft and pulley ID as shown in this picture. It was just being clamped down with a bolt and washer.
This picture shows the thickness of the pulley ID.
I had been mowing with this for about 2 years, and if that is incorrect, I'm surprised it lasted that long.
Thanks.
N3PUY
I would say that it was the correct "double D" pulley and has rounded out.  It is the same thing that happened to the neighbor's pulley.
The STEEL shaft is harder than the cast IRON pulley.
Hoffertot
Garry
Thanks for the manual Garry, you happened to post the one for a 77, is this what year you determined it to be from looking at the pictures? Or did you mean to send an 87 one? Are the pulleys the same?
gwest_ca
I think that was the last 42" deck model to use the double-D shafts. There is a list of decks on that page in the order they were produced so yours could be older and one of those.
There is also pages that show the spindle assemblies over the years that could be used to upgrade the assemblies. Nothing saying the newer decks could not have received older used replacements.
This is the next model of deck that was produced and it uses 3/4" spindle shafts and they are both 1977 models - a mid model year change.
Garry
RJS    Cutter
I am having a similar problem.  I hit a stump while cutting now the middle spindle shaft seems to not be attached to the pulley.  Is there a pin or key that may be sheared or was this the final straw that damaged the assembly.  I have not torn things apart yet, just figured it out and am at the research stage.  Any information you can give me would be appreciated.
Thank you.
Hoffertot
Thank you.
Sorry for the late reply. I think I have come to verdict that these guys are correct in saying that the double "D" pulley has rounded out on my rig. The part number for the pulley that replaces it is a Toro 106847, but I have not had a lot of luck finding any online. Seems like they are quite rare these days. It appears there is a round hole version of this pulley as well, but I am not entirely sure on how it is attached. Maybe press fit on the shaft, set screws, or just clamped? Maybe once you pull it apart, it will be obvious what the issue is.
  • Similar Content
    • Jayzauto
      By Jayzauto
      Toro - WheelHorse Deck Chutes available.  Fit 42” & 48” Side Discharge Decks.  These are New & Restoration Quality.  I have 2 available.  $50ea/BRO
    • 87buickt
      By 87buickt
      Listing for a friend, late 70s I believe D200 deck and plow. Been sitting for a while, make reasonable offer, friend also has tons of literature he may part with, if Interested let me know
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Little Red Horse
      By Little Red Horse
      I am selling a 1970 Wheel Horse Electro 12. It is in *working condition*.
      It has AG tires and a mid-mount blade from wheel horse.
      It also has a front mounted generator that currently doesnt put out power. It has been in the barn quite a while, so it may be a corroded connection,  not sure. Although there's not too much that goes wrong with them.
      The tractor has been a great one for me. The last 6ish 7ish years that I've had it where I lived it brought the gravel back up my driveway for me every time it rained. In the last few months, it would run for 20-30min then die.
      I was moving at the time so just didn't have the time to look at it. And it seems I still don't. Where I am currently I don't have a place for it. I don't want it setting out and deteriorating. So here we are.
      Please contact me by text or email.
      Thanks for looking!
    • ohiofarmer
      By ohiofarmer
      i know that there is ebb and flow with market conditions, but I have been seeing bargain 520 and c-160 prices more common. I recently saw a c-160 like model on a place other than here that was close by, but i did not get a chance to see it as I was still on a medical tether getting care. i say c-i60 like model because it was a series of numbers like 4455 or somesuch .Tractor had the k series engine clearly a sixteen HP and came with a decent looking deck and pusher blade. i called my buddy Jay and told him for the $250 ask , he better hustle after it. i really do not know if he did.
        I also have been seeing 520s and such lower than I can remember as well as the D series..My theory is that people experiencing paycheck to paycheck living are increasing in number.
      You even are seeing a lot more older trucks like square bodies and especially big blocks than you did before. we used to see this a lot in new trucks when fuel prices hit records.
      i am not claiming expert status on this, but it seems to be trending this way one county next to indiana and 90 miles North of the Ohio River.
       Tell me what you are seeing out there and what you think.
           Edit:  Jay and I ran up to buy Bob Ellison's tractor in MI.  Bob was very nice to deal with and included his "last seat"   I got super lucky buying my first C-160 that did not start and another one shortly dropped in to keep it company. The tractor described above was listed for only two days and was gone
