Bahmi 4 #1 Posted July 24, 2017 I want to replace the belt on my 312-8 and I emailed a dealer. He said the deck had some numbers on it on the back side middle. I found no numbers. However, the deck appears no wider than the outside of the front tires. Would that make it 36 or 37 inches wide? This information allows the dealer to fit the tractor with the proper belt. Share this post Link to post Share on other sites
953 nut 51,018 #2 Posted July 24, 2017 Take a picture of the deck and email or text it to the dealer, should be able to work from that. 2 Share this post Link to post Share on other sites
daveoman1966 3,562 #3 Posted July 24, 2017 If the deck has 3 spindles (blades), then it is a 36" deck. If only 2 spindles (blades), then it is a 37" The 37" also has the deck spindles on TOP of the deck...36" decks, the spindles are bolted onto the bottom side. Here is a 36 and a 37 deck 1 Share this post Link to post Share on other sites
