Govlarry dale 34 #26 Posted July 21, 2017 No sir nothing broke just wore out like me.. And i sure hope i didnt offend anyone. Is most certainly was not my intention and if i did i apologize 2 Share this post Link to post Share on other sites
Sarge 3,462 #27 Posted July 21, 2017 It takes a set of Vee blocks and a height measuring indicator - not a simple job to determine the stroke on a crankshaft . Find some local tractor pullers , especially Garden Class - those guys will know who can do the work correctly . Finding machine shops that are specific to Kohlers like Jimmies Machine in Peru, Illinois is a job in itself and will just take some research . Frankly , I stick with older machinists that have been doing this stuff since those engines were new - which is even harder . Sometimes local L&G shops will know someone that can do the work or if you have to bite the bullet at least it's a lighter small block and you can ship out just the short block portion to have it done - be sure to give them the oil pan with it for making sure they have the right dipper to fit that specific pan . If the engine sticker plate is missing it's even worse - they have to determine the series build or spec number of that block to get the right parts - WH has a list of spec numbers for the correct period engine that was originally on the tractor in the model list - it's in the manual section on this site . There are little subtle differences in these Kohlers specific to Wheel Horse specs so this part is important , otherwise nothing fits correctly and will drive a shop nuts . The research will probably be left up to you unless that is the original engine with the spec numbers still intact ...? Sarge 2 Share this post Link to post Share on other sites
Govlarry dale 34 #28 Posted July 21, 2017 Yes sir as far as i can tell the only thing thats been change was the electrical was upgraded and all engine tags are in tact Share this post Link to post Share on other sites
rmaynard 14,861 #29 Posted July 21, 2017 Simple answer to your initial inquiry is that all K181 connecting rods are the same length, whether they are undersized or standard. The only difference is the bearing surfaces are built up on an undersized rod. From the center line of the piston pin to the center line of the crank pin is the same. 3 Share this post Link to post Share on other sites
Govlarry dale 34 #30 Posted July 21, 2017 I will be leaving all measurements up to the machinist. That why they make the BIG bucks 1 Share this post Link to post Share on other sites
ebinmaine 62,937 #31 Posted July 21, 2017 Love this post for all the best and worst reasons.... 3 Share this post Link to post Share on other sites
BOB ELLISON 2,976 #32 Posted July 21, 2017 @Govlarry dale you'll have to excuse all of us guys for taking advantage of your post. If you stick around long enough and read the posts that others start you will see the child come out in all of us. It's all good humor that makes me read here everyday. But you'll get the right answer to every question you have about these wonderful machines. The guys here try to guide every new Member in the right direction to keep these tractors running good. We have a deep passion for wheel horse's and you'll always get help here by the brightest and best. 7 Share this post Link to post Share on other sites
TDF5G 2,051 #34 Posted July 21, 2017 1 hour ago, BOB ELLISON said: @Govlarry dale you'll have to excuse all of us guys for taking advantage of your post. If you stick around long enough and read the posts that others start you will see the child come out in all of us. It's all good humor that makes me read here everyday. But you'll get the right answer to every question you have about these wonderful machines. The guys here try to guide every new Member in the right direction to keep these tractors running good. We have a deep passion for wheel horse's and you'll always get help here by the brightest and best. 3 Share this post Link to post Share on other sites
ebinmaine 62,937 #35 Posted July 21, 2017 3 hours ago, BOB ELLISON said: @Govlarry dale you'll have to excuse all of us guys for taking advantage of your post. If you stick around long enough and read the posts that others start you will see the child come out in all of us. It's all good humor that makes me read here everyday. But you'll get the right answer to every question you have about these wonderful machines. The guys here try to guide every new Member in the right direction to keep these tractors running good. We have a deep passion for wheel horse's and you'll always get help here by the brightest and best. Well said sir. And very true. 1 Share this post Link to post Share on other sites
Govlarry dale 34 #36 Posted July 21, 2017 The best payment, for anything, is knowledge, and i can tell there's a lot to be learned here and i wouldn't want to mess that up....great sight guys....thanks 9 Share this post Link to post Share on other sites
Searcher60 208 #37 Posted July 23, 2017 No matter how long it is, is it ever long enough? Share this post Link to post Share on other sites
jay bee 817 #38 Posted July 23, 2017 On 7/20/2017 at 5:33 PM, Govlarry dale said: So if anyone know of one around Kalamazoo Mi. Let me know.... I can recommend the Machine Shop at Ridge Auto Parts, a NAPA Store located at 250 East Centre Ave. in Portage MI. (269-327-4479). They did all the machine work on my son's Kohler K-301 12HP and they seemed very knowledgeable about the Kohler Engines. It runs like a top and we have had no issues with it at all. If I were to have another engine done I would definitely take it there. I hope this helps you. Jim Share this post Link to post Share on other sites
