tbbahner 27 #1 Posted July 6, 2017 Hey all, I'm in need of a rockshaft setup for a tiller for a 1979 C161. Found one off a 520 that looks like it would fit, it appears to be a short one unlike the pre 1978 ones. Would the one of the 520 work?? Also, how important is the tube the lift cable runs through? Thanks for any help. Share this post Link to post Share on other sites
Busman 14 #2 Posted July 7, 2017 I have heard that running the cable without the tube will wear into the rear end. Share this post Link to post Share on other sites
obone 142 #3 Posted July 13, 2017 Check out this site. Even if you want to make your own or try to use the one from the 520 (unsure if it will work I thought the 520 was bigger). https://wheelhorsepartsandmore.com/ You can also look at this document to see if it will work. Share this post Link to post Share on other sites
