BigMan-TinyTractor
Bizarre fuel issue with a D-250... Never witnessed this before.
BigMan-TinyTractor
,Hi all...
I bought a D-250 a while back and I really like it but she's got a couple ghost problems that I can't seem to wrap my head around.
I believe that it's a '76. It has the Renault engine in it.
So three different times now... I've hit a small stump, stopping the mower dead in it's tracks. All three episodes were moderately violent. In two of the occasions, it stalled the mower after I disengaged the deck and backed off of the stump.
So here's where it gets weird.
After each incident, the mower would no longer start.  If I pulled the choke all the way on, it'd fire up and rev to the sky... Like sketchy high rpms which all three times was the only way I could limp it back to the barn.
After completing cooling down and tweaking the fuel mixture screw back and forth, I've been able to get it to run well again...
Sometimes I can ease the choke off and the governor goes crazy surging off and on... But in most cases, it simply won't run with the choke off.
So what in the heck does this have to do with the impacts?
The only theory I currently have is that it jolts the fuel tank and fuel filter badly enough to shake up some contamination... But that's just a wild guess. It's also definitely temperature related, because I can mess with carb settings enough to fix it so long as it isn't up to temperature yet.
So there it is... Any of you guys ever heard of a crash related fuel issue?
I feel like I'm going crazy. I know I'm missing something here in the troubleshooting.
Thanks a bunch!
Jacob
Dakota8338
Take your fuel filter "out" line off the filter nipple and see if the fuel passing through the filter is nice & clear, or dark, crudy cloudy etc.  If the filter is not passing nice clear fuel, it should be replaced.
BigMan-TinyTractor
I understand completely, thanks.
The fuel filter seems okay.
rmaynard
You are probably on the right track when you say "crash related fuel issue". A complete fuel system flush seems to be the first thing I would try. It also sounds like the sudden impact may have "tweaked" the governor a bit. Since I have zero knowledge of the Renault engine, I am only speculating. Good luck!
ericj
watch the stumps !!!!!!!!!!! mark them so as not to hit them. What would happen if when you hit the stump you lfet the tractor sit and cool down before attempting the restart
eric j
  • Similar Content
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Swemill
      By Swemill
      Hi everyone!
      Long time since i was here and my old pics is gone from the forum.
      I just uploaded a movie with pics on youtube, and thought i could share it for you guys.
      I would love to get some comments on my Youtube channel, from you true Wheel Horse fans!
      Thanks and Best Regards
    • 87buickt
      By 87buickt
      Listing for a friend, late 70s I believe D200 deck and plow. Been sitting for a while, make reasonable offer, friend also has tons of literature he may part with, if Interested let me know
    • Nathan W
      By Nathan W
      Does this look factory for 1976
