Fin_
C-125 Won't Fire
Fin_
Wheel horse c-125 with kohler 301 engine wont fire but turns over. I have made sure there is fuel getting to the engine and there is a strong enough spark to start it. Also we have good enough compression.
So what is the problem?
gwest_ca
Have another spark plug you can try? They will fire out of the engine but can fail when placed under compression.
Garry
Fin_
We just renewed the spark plug, brand new but didn't help.
pfrederi
Is the plug wet with gas after cranking?? if you are sure you have spark and the plug is wet and you have compression then we have to look at timing.  You need Fuel, compression and spark (at the right  time) to have an engine work.  Sounds like you have all three but the spark is coming at the wrong time.Do you have access to a timing light, or a multimeter?
Fin_
Yes I do have access to a multimeter, what do I need to do?
pfrederi
Remove spark plug.  Can you find a small metal plug on the blower shroud. Probably on the front maybe below the coil. Pry it off then slowly turn the engine over there will be two marks punched on the edge of the flywheel.  One will have a T the other an S.  If you have some paint you may wish to highlight them they can be hard to see.  Disconnect the wire from the coil that goes to the points.Then put red probe form your multi meter on that then connect the black one to a know good ground.  set multimeter to measure ohms lowest setting is good.
  The meter will read 1 (open) or show a very low resistance. Then slowly turn the engine over. Hold your finger over the plug hole when you feel compression starting to build your meter should show a very low resistance.  Continue turning very slowly until the meter will suddenly show 1 (open).that is the points opening and when they would fire the plug. Now look in the hole ans see if you can see the S mark.  If you can then you are timed correctly.  However if you can't see it slowly move the engine forward or back a bit until you should only have to move it a fraction of a turn to reveal the mark.  If you have to go forward Clockwise on the flywheel end then your timing is way to advanced if you have to turn it anti-clockwise then you are too retarded.
To adjust points open the cover   A setting of .020 should get it running and have the S in the center of the hole if not readjust points and remember opening points advances the spark closing them a bit retards it.
Edited by pfrederi
Fin_
I looked through the hole at the fly wheel but the edge of it was too rusty to find any marks whilst I turned it slowly.
pfrederi
First check the point gap with feeler gauge.  Turn motor till points are open and not moving. Check gap should be about .020 (which normally will let them start and run...just maybe not so well).  Did this motor ever work for you??
Fin_
Alright will have to borrow a feeler gauge, yes this motor worked very well for me for around a year until it suddenly after a month didn't start
pfrederi
Hopefully setting the points to .020 will get her running.  However to get her runnng her best you will have to get the timing so she fires when the S is in the window.  May have to pull the air shroud and clean up the edge of the fly wheel.  I think Kohler had a 98 pound weakling stamping the flywheels...some are pretty faint.  Whilst you are out borrowing try to borrow a timing light.
Edited by pfrederi
Fin_
I just measured the point gap and it was around .015, would this make much of a difference though? Should I change it to .02.
Fin_
Never mind I just changed it to match .02 and it still didn't fire. Later I'll try and clean up the fly wheel.
pfrederi
Curious how are you testing the spark.  from what I have read if you pull the spark plug wire and hold it 1/8"  from the plug (still in the head) it should jump the gap while cranking (obviously insulate your self from the wire for this test.
If your coil is weak you may have a spark with the plug laying on the head but not when it is under compression
Fin_
Yes we have tested the spark plug in various ways, one of the ways you listed we tried as well 'pull the spark plug wire and hold it 1/8"  from the plug (still in the head) it should jump the gap while cranking'.
doc724
Had the exact same problem.  Found that I wired the condenser to the wrong side of the coil.  everything I read said that it should not make a difference-short term ...but it did.  Put it on the correct side and it fired right up.  Learn something new every day
Tim.0
IF you have a compression checker or gauge you can also use it to find TDC (top dead center). You can get a little tissue paper also and not plug the spark hole tight . but lightly tight an under compression the tissue paper should pop out this showing your on compression stroke and getting close to TDC to find your fly wheel mark
Edited by Tim.0
gwest_ca
Have used a piece of wood dowel to ride on the flat side of the flywheel. Easier done if it will run but have done it with the spark plug removed and cranking the starter. The dowel will polish the rust where it contacts the flywheel and leave the timing mark untouched so it is visible.
Garry
6bg6ga
Does removing the spark plug allow one to insert a dowel rod into the cylinder and touch the piston top? If so simply insert a dowel rod and rotate the flywheel until the piston comes to TDC and then take a paint marker to mark where the missing mark is.
Edited by 6bg6ga
6bg6ga
Engine won't fire. Check to see if there is voltage to the ignition coil when in start and in run with your meter. If no voltage make up a jumper wire to go from battery to the coil + and with the plug back in try to start it. If it still will not run swap out the coil and try it again.
clueless
Garry
:text-yeahthat:
Fin_
Alright will try all of these and get back to you this weekend, thank you for your help.
pfrederi
That doesn't work on K series Kohlers Plug is not over the piston
6bg6ga
I guess that would be obvious to anyone removing the spark plug. No real need to find TDC anyway. At .015-.020 its going to be close enough for the engine to start anyway. Visual observation of the points alone would supply enough information.
Edited by 6bg6ga
Fin_
I just tried getting rid of the rust on the flywheel so I could see the marks on it but couldn't find anything, is this good enough to be able to see the marks?
Tim.0
use a bright flashlight and go slow I would think you would be able to see it. Unless it was stamped that bad. I found mine and it had more rust on it than that, then maybe it was just stamped better. use your hand so you know your on the compression stroke and it might help narrow it down some.
The rust may be in the stamp yet you might find the stamp by the outline.
It gets frustrating I have been down this road before just take your time.
Also when the points close make sure you have continuity you can use your multi meter for that. Sometimes the points need to be cleaned up some. Had this  happen this spring when I try to start a ford tractor that had sat over a year. I tracked the problem to the points not making contact, but they were closing and gap was correct. I clean to points with  emery cloth. Then rechecked gap,I rechecked with my meter and had continuity when closed, I didn't have continuity before. Put the distributor back together and tractor started right up.
  • Similar Content
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
    • Tenday
      By Tenday
      Experts - help please. I’m new to Wheel Horse Tractor life!
      So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
      I’m looking for help on diagnosing no spark.
      model - 417-8
      engine - Kohler KT17
      Done thus far:  (aware that some have no implication on spark.)
      - new ignition switch
      - new battery
      - new starter
      - new ignition coil and wires w/ plugs
      - new condenser
      - new points
      - new starter solenoid
      - bypassed all switches except oil and seat.
      notes:
      idiot lights removed.
      All fuses tested with Ohms as well as visual inspection  ..
      coil tested w/ ohms as well
      all switches bypassed except:
      -oil switch  ( don’t think it has any implications other than a visual indication for idiot lights. )
      -seat switch
      ran a pos from batt direct to pos of coil - nothing; no spark.
      Electric is as follows:
      - Starter switch wired to solenoid
      - - solenoid to starter
      - - solenoid to batt
      - one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
      - I have two yellow wires, which are married up, that go to engine which have constant power; They power coil.  Comes from switch and seat.
      Help - what the heck am I missing ?
