69-Raider-10
The 69 Raider 10 getting a makeover. Almost Done!
69-Raider-10
SylvanLakeWH
Nice Job!
69-Raider-10
On 6/23/2017 at 10:43 PM, SylvanLakeWH said:
Nice Job!
Thanks man!
Digger 66
Lookin' good :handgestures-thumbupright:
Chris G
Looking good!
Joshn569
On 6/23/2017 at 9:45 PM, 69-Raider-10 said:
More pics..
Do you have a pic with those decals on it?
Graydon
I can see you've put lots of time and effort in to your creation, looking very good. You might want to incorporate a starter solenoid between your key switch and the starter motor, outherwise you will burn out your key switch.
Sarge
If it has the older Cole Hersee ignition switch they are designed with very heavy contacts to handle the starter load. It's still not a bad idea to use a solenoid hidden somewhere if you want to keep the clean looks - removes that battery power out of the dash and from behind the fuel tank. Same design on my old 1277 - always disconnect the batteries on those prior to touching anything in that dash, lol....or boooom.
Sarge
953 nut
:text-coolphotos:     I like your idea of a "Key On" light on the dash.        :handgestures-thumbupright:
 Here is a very simple diagram for a battery ignition system with a solenoid. Like @Sarge said, you don't want un-fused electrical power behind the gas tank. I know that is how they were built but it isn't the safe way to go.5a89beeaba8d2_batteryignitiontractor-wiring.jpg.0c60cbbb647933981578063f3cf7cb35.jpg
Sarge
Plus, the use of a solenoid will extend the lifespan of those rare Cole-Hersee switches - they do not last forever when the starters get worn or have a bad set of brushes, especially the older starter-gens . I plan to update my 1277 when I rebuild it - hate having that much amperage sitting in the dash. They worked fine, but it's a danger that wasn't necessary in my opinion and hd solenoids were available at the time these were built , albeit a bit larger than what we have today. Put a modern agm high CCA battery in an older tractor and those switches won't last all that long too, just fyi.
I can't recall - did the '69 Raider use the L key or just a straight one ?
Can't wait to see that one done - it's going to be pretty nice, great job.
Sarge
69-Raider-10
Funny you should ask Josh! I do! Im just now putting the final touches on her! All I have left is drilling holes in the straight pipe to baffle the sound and slow the air down coming back in, hook up the LED mini bar and fit the headlight cover back on, adjust the governor, hook up the backup light, and time the ignition one more time. She hums beautifully in idle but shes breaking up pretty good when I throttle up. I'm a little concerned actually. I dont think the ignition timing is far off at all. Maybe a 1/4" from the S mark on the flywheel when the points crack. Ive had worse than that and barely noticed a problem. Nut? Sarge? Any idears?
Heres a few pics recently. Remember, I wasnt doing a restore, this is my cutting tractor so its made for my needs but pretty. LOL Ag tires arent on in these pics either. And the rims arent painted yet. Add that to my todo list.
Its a push button start because of the motor swap. Went from a Lauson (Tecumseh) 10 with SS Ignition over to a K181. I hated the SS ignition. I added a 12v power source (cig lighter), and used the solenoid off the Commando 8. I just picked up a new baby today to play with. Look for a new post on that one. ;)
  • Excellent 2
69-Raider-10
69-Raider-10
  • Like 5
  • Excellent 2
Joshn569
2 minutes ago, 69-Raider-10 said:
Looking good. I like what you have done with the headlight
69-Raider-10
Thanks man! Its a hell of alot brighter thats for sure! :lol:
69-Raider-10
Does it look better now that its wired up? I have a solenoid in there.
69-Raider-10
Sarge
Thsnks Sarge! I do have a fuse coming off the Battery post on the switch I believe? Solenoid is in there by the starter in front of the battery box. I'll snap some more pictures tomorrow.
I am concerned about the breakup just past idle. It sounds like if you had your choke halfway closed when it was warm and you maxxed the throttle. Any suggestions are appreciated! Thanks again!!
classiccat
the tractor is lookin' mighty fine!
have you fiddled much with the mixture settings on your carb?
Edited by classiccat
Sarge
Either the timing is off too far or the main run jet in the carb is plugged up. Have you checked the governor setting?
Sarge
953 nut
Your ignition points also set the ignition timing so you should use the static timing method to set them. may want to remove the flywheel cover to locate the timing marks and make this easier.
Kohler static_timing.pdf
69-Raider-10
I actually swapped carbs with my 854 and it did the same thing. I'm at a loss on this one.
69-Raider-10
Sarge
Thanks for the suggestions fellas. I actually swapped points out, set the gap twice, and static timed it as many times. One of the first things I do when I get a K Series motor is pop the blower Housing and clean/paint the 20deg and TDC marks on the flywheel, along with the timing mark on the block. Makes for easier timing in the future. This thing is almost dead nuts (if not dead nuts) on. I didn't fool with the governor setting. That could make it break up at higher RPMs? Never thought about that before.
Another thing I noticed today is it has no power to the wheels. It moves real slow when at a fast idle before it breaks up, but going up a small incline it barely turns the wheels. My other Horses at idle would be hard pressed to be stopped by much anything. Recently replaced all the seals and gaskets. Could I have forgot one or something? Man this is making me crazy. Thanks for the help gents. Much appreciated!
redone
I am just stopping by. I restore these old tractors, running out of room. Do you keep track of your labor time? I also rebuild old kohler. Still on the pallet
I notice you paint the whole engine, I have my blocks blasted. Then prime then top coat red. But I don't paint the cylinder fins. This helps keeping the engine cool.
Nice job on restore.
  • Similar Content
    • AndyZ
      By AndyZ
      Operator manual #A-5274
      Wiring
      6 pages 7.31MB
      Illustrated parts list link
      Use the 1970 parts list for the Raider 10 model 1-6051 and Raider 12 models 1-6251 and 1-6253 with the following exceptions
      For 1970 electric clutch use Electro 12 model 1-7255
      2 pages 282KB
      We also have the 1971 tractor parts manual that followed
      1971 Raider 10 model 1-0300 - (1-0300-6) - Uses HH100-115145C with magneto ignition (Engine oil capacity 2 quarts)
      1971 Raider 12 model 1-0310 - (1-0310-6) - Uses K301S-47407C with breakerless magneto ignition (This model also made in Belgium) (Engine oil capacity 2 quarts)
    • mmmmmdonuts
      By mmmmmdonuts
      My cheap-o walmart U1 battery is starting to bite the dust again (barely able to crank it over fully charged, and ozzing everywhere) after 3 years on my 68' Raider and I am looking into a new battery for winter as I now have a plow setup. I was thinking of either getting the original 22NF battery that came with it or running a mazda mita battery which is a U1 size. Is the AGM worth the extra money over the 22nF even in the smaller size? I think the vibrations keep killing the cheapo batteries and I am trying to make sure I can leave it out in the cold and not have a problem starting in the winter. It does get down to 0F or below zero every once in a while. I don't think I want to go all the way to a 22nF AGM as it is $200.
      Thoughts?
    • ohiofarmer
      By ohiofarmer
      I am picking away at the k series on the raider10. Basically the Piston blew through at the ring grooves as it appears the rings may have had too large a gap. I can feel a slight erosion of the bore where the ring gaps All lined up, but not even close to catching a finger nail.
      I am hoping just hoping out the bore will get it back to round close enough that a ring job will do .
      In any case I can measure the bore and report back. Discipline demands that I do not tear this engine down right now as too many things are taking up my time.
      Just hoping the gurus can offer a bit of guidance
    • davidtmercer
      By davidtmercer
      Just recently had a 10 pinion differential axle gears lose their teeth as shown in this picture from a post in 2014.
      Was wondering if others have had this happen and if they determined the root cause and corrective actions.
      I am considering replacing the two axle gears and five pinions that were destroyed but did not want the same thing to happen again.
      I assume the failure was due to a worn cylindrical spring that I also plan to replace.
    • 12 hp Kohler
      By 12 hp Kohler
      Been looking at a lot or Raiders and Chargers lately and was wondering if they all have LSD? I know most of them did but I was wondering if some of the later models might have had the Uni drives instead ?
      Thanks, Robbie.
