njdpo
Kohler K181 rebuild
njdpo
Hi all,
Back in 2011 you guys assisted me with getting my Commando 800 (engine K181) running properly (http://www.wheelhorseforum.com/topic/27577-wet-cooling-fins/#comment-234931 ).
6 years and many happy memories later that little K181 still runs – but she’s tired. She was tired when we got my issues all ironed out. I never did get around to dropping a new piston and rings in it. At this time the engine is down on power and blowing blue smoke - I dont want to blow up this motor if it can be refreshed.
I was thinking of sending the motor out – but I decided I will help my 14 yr old son (Willy) rebuild it. Hopefully I can keep the rebuild costs down – and Willy will learn something interesting.
a few questions for the group:
  1. Is it possible to upgrade the K181 points ignition to electronic (without breaking the $bank$) ? The points are OK - but im wondering if the motor could benefit from an electronic ignition.
  2. Are any of you aware of a document(s) of tips and tricks, and/or procedural documents for going through this rebuild process?  Thinking of things like:
  • - Gunk motor off before removal & disassembly
  • - Take picture of carb configuration before removal.
  • - Paint inside of motor with this paint / - Paint outside of motor with that paint
  • - Break in procedures.
Please let me know if you have any questions that I can answer up front.
Any advice you have is greatly appreciated – and yes I will be posting pics as we progress through this.
Thanks, Dave
Edited by njdpo
pfrederi
The K series single manual in the manual section here pretty much cover the topic.  You do not need to paint inside. Lots of pictures hlep failing memories.
Achto
Here is a Kohler manual.
I actually prefer an automotive coil & points set up. It allows you to work on the ignition system without pulling the fly wheel. Cleaning the engine off before you disassemble definitely makes thing more enjoyable. After disassembly you'll want to take your block & crank to a machine shop to have them measured so that you will know what parts to order, (over sized piston, under sized rod). The machine shop will then want the new parts before they do the machining. No need to paint the inside of the engine, unless you really want to spend the cash on Glyptal internal engine paint. Most enamels will work good on the out side of the engine. Take lots of pics while disassembling to help with assembly.
As for break in, return to use as normal remembering to keep you RPMs up so that the oil gets splashed around inside the engine as needed. Remember 3/4 & above throttle is actually better during break in. Change oil after the first 5hrs, then return to normal oil change intervals.
Shynon
JimmyJam
K181 points ignition is a easier fix. Electronic breaker-less ignition (solid state) is tough to find and expensive to replace.
RandyLittrell
Kirk engines sell a point replacement. Here is a llink.
http://www.kirkengines.com/
Randy
njdpo
Hi Shynon,
13 hours ago, Shynon said:
Coincidentally I am a bit of a documentation specialist.
I would be happy to proof-read that document for you ... :)
and you can document the k161 and k181 - - - if I can fwd a few k181 pics to you.
Thx - Dave
Edited by njdpo
njdpo
12 hours ago, RandyLittrell said:
Hi Randy - interesting link - http://www.kirkengines.com/
I see they sell electric fuel pumps - I installed one of these on my Case 444 (when the old mechanical pump died).
I like that the electric fuel pump can prime the carb bowl before cranking the engine ((( I  get instantaneous engine starts on the coldest of winters )))
My commando 800 - has the gas tank sitting above the carb and pump... ( I like this setup )
I'm afraid that a 40+ year old mechanical fuel pump could dump raw gas into the the sump and destroy a newly rebuilt engine (especially with the gas tank sitting above the mechanical fuel pump and carb).
QUESTIONS:
  • Does anyone know if I can eliminate the mechanical fuel pump and just let gravity do the work ?
  • Is it true - that a torn diaphragm in a mechanical fuel pump could contaminate (thin out) the sump oil ?
  • If I dont need the pump - I guess I could just bypass it and go from tank to carb directly? (and eventually install a block off plate where the mechanical fuel pump was )
I could bypass / test this idea today - before I tear apart the engine.
A vacuum fuel pump is another alternative - I guess. I don't think cold winter starts would be a problem either - since there would be ( little possibility ? ) of gas draining upwards to the tank above it.
Thanks - Dave
Randy
Edited by njdpo
pfrederi
My lawn Ranger has had no fuel feed problems in 50 years...gravity is nothing if not reliable:P.
However the bottom of her gas tank is 1/2" higher than the carb fuel inlet.  i think if you measure the distance from the floor you will find  the bottom of your tank  is slightly below the carb inlet.  If you kept it mostly full it should work but it would die before the tank was completely empty.
Achto
You can eliminate the factory pump, some have gone to an electric pump. Some have also replaced the old metal body pump with the new plastic body pump (all new pumps, even Kohler brand are plastic now). I personally rebuild the old metal body pumps and have not had any issues.
njdpo
I'll break out the tape measure and have a look at it - thanks !
If the risk of dumping gas into crank case through a bad fuel pump is real  - i think i can live with keeping the tank topped off
Or replace it with a vacuum pump.
Thank - Dave
  • Similar Content
    • Rick3478
      By Rick3478
      For Sale NOS M12S Short Block, still in the original box.  I bought it pre-emptively when Kohler was phasing out the Magnums.  Thought I would have it on hand if one of mine needed it, or maybe I would find a tractor with a busted rod for cheap.  Neither of those things happened, the darn things just keep running.
      Part number 77 522 35, probably built in late '05, it's the combination replacement kit Kohler made to fit WheelHorse or Gravely, machined to bolt directly into the Gravely transaxle, but also has spacers to mount WheelHorse PTO clutch/brake.  Also has a bunch of gaskets and seals packed with it, probably all you need to install it.
      And it's heavy, so it's not practical for me to ship.  Buyer arrange to pick up near Elida OH, I can lift it about knee high to help load.
      Asking $800 or might consider trade for a good center mount grader blade.
    • mcfarmall
      By mcfarmall
      Tractor features Kohler 16hp cast iron engine, gently used 42" deck, concrete wheel weights, tire chains, new Chinesium carburetor, fuel lines and filter, new air filter, 2 new fwd/rev cams.  A starter,  some new gaskets, and miscellaneous parts.  New drive belt and all the belt idler assemblies.  Engine runs but smokes.  Great restoration candidate or a spare engine for you pullers out there.  Call, text or email for a private showing.   No offers considered unless made in person.  Buyer responsible for transportation.  Many more pictures to send to interested persons.
    • Jeff-C175
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • Kenneth R Cluley
      By Kenneth R Cluley
      Got my parts from Lincoln, governor gear and shaft. So, I started assembly today. Took me three tries to get that two-piece crank in, thankfully it was within spec when done so I didn't have to take it back apart to shim!  Got the crank in, lapped valves and ground to spec. I found this old aluminum fixture from a hospital bed oxygen filter mount and squared it up on belt sander that worked really well on valve stem. Progress at last, will finish up soon. Hope it runs well when done! Going to put it on my 653.
