tbirdsteve 11 #1 Posted June 20, 2017 G'day All, I have a question about my 1993 520H with Onan P220g engine. It seems the starter motor has decided to retire. In order to purchase a new motor or repair parts from the web, I need a model number. The decal showing the model number is damaged right where the last 2 numbers are (murphys law). Can anyone tell me what model it might be?? The solenoid is fine but the motor itself turns for a few seconds, slows then stops (just in case anyone has an idea what the problem might be). I have opened it up, cleaned it out, brushes are good, armature checks out ok. Thanks in advance. Share this post Link to post Share on other sites
rmaynard 14,888 #2 Posted June 20, 2017 I can't tell you the model number, but I'm sure others will jump in with the correct info. However, I'd suggest that you just go to eBay and search Onan P220 starter. You will find lots of choices, new, used, rebuilt, etc. with prices to fit any budget. 1 Share this post Link to post Share on other sites
lynnmor 6,764 #3 Posted June 20, 2017 Have a voltmeter on the starter and check the voltage as it slows and stops. The problem may be something other than the starter. 1 Share this post Link to post Share on other sites
oldlineman 1,450 #4 Posted June 20, 2017 No sure but from your picture the last two numbers look like 04 worth a chance and try using them. 1 Share this post Link to post Share on other sites
EricF 589 #5 Posted June 20, 2017 Do yourself a favor and check all the wiring connections that the starter draws power through -- especially the grounds. Poor grounding may allow the initial voltage through to operate the solenoid and spin the starter, but the load increases as it works against the engine's compression. Voltage (and starter speed) may drop when the current won't flow because of a bad connection or ground. 1 Share this post Link to post Share on other sites
boomers_influence 106 #6 Posted June 20, 2017 tbird the starter # is 191-1949-04. 191-1808-04 is the prior # thank you. boomer ( the used onan engine parts guy,also NOS and new) 1 Share this post Link to post Share on other sites
tbirdsteve 11 #7 Posted June 22, 2017 (edited) Thank you All, it is indeed an 04 model once it was pointed out. Appreciate all your replies and will follow all advice. Boomer I may contact you in future as the next step is removing the flywheel for inspection. There are many small pieces of magnetic metal stuck to the shroud so I would guess the magnets on the flywheel have self destructed. Just out of curiousity, are the magnets available separately? I see lots of videos on youtube about gluing magnets but google is unable to locate magnets as spares. Many thanks, Steve. PS I haven't seen this motor run yet, although I was assured it does, but i'm tending to think more a case of it did. I'm restoring this tractor to use. Edited June 22, 2017 by tbirdsteve Share this post Link to post Share on other sites
