DennisThornton
The BIG 200 series
DennisThornton
I'm pretty sure many (most?) here ignore or even turn their noses up when they see a vertical shaft tractor, even if it's a Wheel Horse.  I know I always have.  After owning a 264-H for awhile, and finally getting around to mounting the deck and mowing a couple times I must say that I can't tell which way the crankshaft is spinning!  Looks and feels like a good old Wheel Horse to me!  I've never found the need for more than 14hp using a 48" deck but more is better when it comes to snow blowing so there's still up to 6 more horses available up to and including the 270.  I LOVE the forward/backward foot control!  Makes me think I'm on one of my xi's until I notice there's no power steering!  Man if this tractor had PS it would be the cat's meow!  Manual lift but I see little need for hydraulic lift for the deck and I would NOT want it for dozer blade use though I would for a snowblower.  Mine came with a nice blower but I'd rather have a dozer blade with this.  Never used a hydro, especially with foot motion control with a blade but I think I would like that a lot!
However!  I find that they command a pretty good price compared to the Classics.  Perhaps because they are newer and the paint is still shiny?   Don't know...  I got mine for cheap because the owner didn't change the air filter that was so plugged that it would seldom start and if it did it belched out black smoke.  New filter and plugs and she starts right up, runs great and with no smoke.
So if you have a chance to grab a big 200 series I'd suggest looking at it.  As long as it's not near ME!
  • Like 6
squonk
I had a 200 series 10 horse for twenty years. Beat the snot out of it and it did everything I ever asked for it. I had to buy a diode and tie rod for it and that was it! :banana-wrench:
Sparky
I've been watching Craigslist in my area for one to pop up that's reasonable. Each time they are either way overpriced or something major is busted.
  Mike....
  • Similar Content
    • nickjet67
      By nickjet67
      Hello all, I recently acquired a "new" B-115, and with the help of @ohiofarmer, I will be fixing her up, first with a engine he is trading me for my old Kohler engine off my '77 B-80 that I trashed when I was 13. I haven't been in the Wheel horse game long, as I am 16 now, I hopefully will be able to keep this project updated on here, especially in the spring when I will be completely repainting it! I am super excited for this project, and am ready for all the challenges that lay ahead with it. if you have any helpful information you are willing to share about my newly acquired project, please share! I haven't had tons of luck finding tons of information about it.
    • aboutime
      By aboutime
      I just got a CG7. I was wondering if anyone has tried anything to raise the mower deck height. The mower is adjusted as much as possible. The only thing that I see to help is to put taller tires on it. Does anybody have any suggestions.
    • Dresden Guy
      By Dresden Guy
      Operator manual #810661R1
      Part 1 - 3 pages 4.39MB
      Part 2 - 4 pages 3.59MB
      Dated 06/89
      Fits some 200-Series lawn tractors
      Power grass collector 07-31PS01 available for this deck.
      This is a better copy than the one that can be downloaded from Toro.
      See product service bulletin "WH89-90 #T28 216-H 30in Mower Belt"
      Mower 35-30SL01 serial # 20987 and lower requires longer belt # 114421 if used on a 216-H tractor
      Mower Rotary 1990 30in SD model 35-30SL01
      1990 serial numbers that have shown up for the 35-30SL01
      0020987 - Shown in PSB #T-28
      0022777 - Build date 1990 0005 January 05 Friday
      0023367 - Build date 1990 0078 March 19 Monday
      0023422 - Build date 1990 0078 March 19 Monday
      0023423 - Build date 1990 0078 March 19 Monday
    • Jparkes43
      By Jparkes43
      Hello on my kawasaki 227-5 17 hp single cylinder i was thinking about putting a straight through pipe on it and people time and time again were mentioning burnt or warped exhaust valves and i have no idea how bad this is or how common it is so i just want to know if i should or shouldn't straight pipe the engine
      thank you
      James
      see my other thread about tachometer gauges
    • Jparkes43
      By Jparkes43
      Hello I have a Wheel-Horse 227-5 with the 17hp kawasaki single cylinder engine and was interested in putting a tachometer on it (just because i won't too) but i need a step by step guide as I'm not sure what exactly i need to do, also if anyone could advise on a good tach to use that would help a lot, while I'm at i thought that i might put a oil pressure/temperature gauge on it.
      thank you
      James
