Jamie Darian Brown 9 #1 Posted June 1, 2017 Will a 36" tiller off a C141 work on a B80 8 speed? As far as hook ups and such.... Share this post Link to post Share on other sites
Lane Ranger 10,472 #2 Posted June 1, 2017 (edited) There were special instructions on the 76 and 77 Wheel Horse tractors for the later tilers. There should be a Special Service Bulletin on Red Square for this. The issue is the way the rockshaft lift in the rear works on the Pre-1978 tractors for the tiller. 1976 and 1977 B and C-Series tractors require Service Assembly 1051621975 and prior models require Service Assembly 105105 Edited June 1, 2017 by Lane Ranger 1 Share this post Link to post Share on other sites
Jamie Darian Brown 9 #3 Posted June 1, 2017 Thank you So I can modify it to fit my B 80.....? Just may need to source some parts and alter some things? Where can I find the Special Service Bulletin? Share this post Link to post Share on other sites
Racinbob 10,260 #4 Posted June 1, 2017 You won't need to modify the tiller at all. You may or may not have the rock shaft under the seat. They tend to be somewhat year sensitive. In 1978 the fuel tank was moved under the seat changing the design of the shaft. Take a look at this: It's item #66. I'm guessing you have a 76 or 77 B-80 so this would be what you need. You can actually get by without the rock shaft but lifting the tiller works better with it. The axle bracket and front idler will interchange. 1 Share this post Link to post Share on other sites
Jamie Darian Brown 9 #5 Posted June 6, 2017 Ok. I found a tiller that will work and with it comes the bracket to hook it to back and the idler assembly for the belt. The only thing the idler assembly is missing is the spring and the pulleys and the guard. I can fab up a belt guard and buy a spring and pulleys. My questions is what size are the two pulleys.... the smaller flat and the bigger v ...? Thanks for all your help y'all Share this post Link to post Share on other sites
