RJR49 121 #1 Posted May 14, 2017 I was mowing the yard and when I came around I found the cover to the mule drive laying in the yard. The nut and outer spacer were nowhere to be found. The local hardware store had the nut but, of course, no spacer P/N 101757. Since it has a different P/N than the inner I suspect they are different. If anyone knows what size it is I can make a new one. Otherwise I'll have to guess Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,495 #2 Posted May 14, 2017 1/2" long spacer part number 101757 is on the outside between the pulley and cover. 5/8" long spacer part number 101734 is between the pulleys. Spacer ID needs to slip over 3/4" shaft. Garry Share this post Link to post Share on other sites
