Similar Content
By Joe Warren
New Old Stock Toro/Wheel Horse Blade Kit #108004
This kit contains two # 108171 blades
Diagonal length: 18 3/4”
Blade width: 2"
Center hole: 13/16” x 1” double D slot
Used On: 37” Side Discharge Mower (1981 - 1983) Models 05-37MS01, A5-37MS01
$39 includes shipping within US lower 48
One blade set available. Limited number of other NOS mower parts available (blades, belts, spindle components). Please private message me if you are interested in purchasing.
Thank you
joeww121@gmail.com
By Joe Warren
New Old Stock Toro/Wheel Horse Blade Kit #106637
This kit contains three # 106078 blades
Diagonal length: 16”
Blade width: 2"
Center hole: 3/4” diameter
Used On: 48” Side Discharge Mower, VIN/Models: 05-48MS01, 05-48MS02, 05-48MS03, AS/05-48MS02, 05-48MS04, 05-48MS05, 05-48XS01, 05-48XS02, 05-48SY01, 05-48SY02, 05-48SC01, 05-48SC01, 05-48SS01, 15-48SC02, 15-48SC03, 75-48MS02, 75-48XS02, 85-48MS01, 85-48XS01, 95-48MS00, 95-48MS01, 95-48XS00, 95-48XS01, 74352, 74353, 78260, 78261, 78290, 78360, 78361, 78363,
$49 per kit which includes shipping within US lower 48
Two 106637 blade kits available. Limited number of other NOS mower parts available (blades, belts, spindle components). Please private message me if you interested in purchasing.
Thank you
Joeww121@gmail.com
By TN Dave
Hi all: The people on this forum have been helpful in the recent past, so I'm hoping that those of you who are more mechanically-inclined than I am (...which is 100% of you, I'm sure...) might be able to point me in the right direction again.
My apologies is this is too basic, but I have an old 310-8. It has 3 mower blades, and I can't get any of them off to sharpen them.
If I use a floor jack and a couple of jack stands, I can lay down on the garage floor but can barely get a 3/8 inch electric drill with a sharpening stone attachment properly angled against the blades. I've also put the front wheels up on plastic ramps (Rhino Ramps) which I use for changing the oil on my car, with pretty much the same result.
These work OK for touching up the blades just a bit, but the blades really need a good sharpening, so I am trying to get them off in order to use a bench grinder.
I have sprayed a pretty fair amount of penetrating oil on the bolt heads above and below the point where they go thru the blades. I have used the longest pipe wrench I have (18 inch). Frankly, I'm a bit concerned that the amount of leverage I'm using might pull the mower off its jack stands.
In any event, the blades are still very firmly attached.
Any suggestions on how to get the blades off will be greatly appreciated.
Many thanks in advance.
By Giff Kucsma
I just replaced the spindle bearings in my RM-367 mower deck. I have a new set of OEM mower blades, but I'm wondering if anyone has found a good way to balance these blades that do not have a round center hole in them.
