cafoose
New coil installed on my 520-HC
cafoose
7 hours ago, 6bg6ga said:
Some people would try to tell you that you need to take it to an engine shop and have them do it and pay them. I will tell you to go to Harbor Freight and buy a puller set and do it yourself
I have a Craftsman harmonic balancer puller set I believe that should work I pulled Kohler flywheels with it.
5 hours ago, boomers_influence said:
cafoose
you ARE NOT doing the module test correctly.
please e/mail me and i will send you pages 8-1 and 8-2 from the P service manual.
:text-thankyouyellow: I have the manual I will look at those pages and follow the recommended steps.
ericj
cafoose, if you are coming to the little guys show in Windsor this weekend, I'll be there and I can bring my good meters with me and test what ever you need to test, working the night shift this week but I'll be there on Fri, sat and sun if you need help. I do HVAC so I have a Fluke, and a UEI that I use at work
eric j
6bg6ga
To be safe and I believe I described this procedure before take pos coil module wire off put 12 v to it take neg module wire off the coil attach one probe lead to the neg lead and the other to ground and turn over by hand to get your 12 signal and then low voltage signal. This procedure tests the module without ANY safety switches in the circuit. No proper signal 12vdc to 1-1.5 vdc means to module is bad. The module staying at 12vdc means the module is bad. The module voltages not going to 12VDC means the module is bad.
The module voltage MUST fall between the specifications or it is flawed. Having said this....one MUST first test the battery voltage that your supplying TO the module. Less than 12 volts to the module will mean less than 12 volts out of the module. I do believe there may be a diode in the module so expect a diode drop of say .6 volts so I would expect 12.6 in will yield 12 out.
6bg6ga
Puller needed to pull Onan flywheel
Harbor Freight under $25
Provides everything you need  except a helper to hold the flywheel.  Note... do not stick anything thru the flywheel vanes because you could destroy them or several of them.
Sensor ring that works in conjunction with the ignition module.
Have marked it to show where the magnets are. There is a "N"  and a "S" magnet and if my conception of the circuit is correct one magnet turns on the Hall effect switch and the other magnet turns off the Hall effect switch.
Gently pull it off the crank and check with a magnet by holding a magnet close to it while revolving the ring. If its good it will pull and it will push roughly where I have marked this one.
cafoose
I just found this thread very informative:
cafoose
That looks like my craftsman set.
Edited by cafoose
cafoose
eric j
I'm not sure if I can make it very busy this weekend. I ordered a new module from ebay and it will be here estimated delivery on Saturday. I already replaced the coil and I'm sure the module is bad based on the tests I did and I don't see any other thing it can be other than maybe wiring. I have a question since you do HVAC. My central air is not cooling like it should. I had several different technicians look at it and the first one said the txv valve is bad. I have a service contract with One Hour HVAC and they said I need a compressor. Are you able to help me with it sometime? It has the R410A system and it's a Bryant installed in 2005.
6bg6ga
I'll bet your craftsman costs more.  I have to save my money for more guns.
cafoose
It did but I use it a lot and it's better quality I've seen cheap ones bend and strip threads.
6bg6ga
A smart buyer.... You invest and purchase the best tools that you use in your particular field. Cafoose bought a really nice puller because he uses it a lot. I bought a cheaper puller and use better bolts with it because I don't use it that much. I use my meters everyday at work and to check the toys I play with hence a lot of different meters for different tests.
They should actually be merged so the next person has a better shot at good information.
ericj
call my home phone 717-244-2317 and if I'm not there leave a mesg with wife or machine and I'll call you back. a big difference between a txv and a compressor, but a bad txv could make a compressor look bad. give me a call sometime going to try and get enclosed trailer down to windsor to day and have to leave for work before 1 pm. didn't get home till almost 2 am this morning, will be gad when this job is done and back to more normal hours
eric j
  • Similar Content
    • gwood
      By gwood
      Question: I'm looking at the seat and decal drawing and could use an answer! Does the the seat spring or the adjusters go under the seat? It looks like the adjusters go directly under the seat and then the springs under the adjuster. If so, where does the spacer (110932) go?   The reason I ask is the seat is quit low and the back sets low making it hard for me to reach the brake/ return to neutral pedal.
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • Joe Warren
      By Joe Warren
      Onan model BF-MS2425A Engine for parts. This engine pulled from NOS Bolens QT16 tractor that sat for 40+ years. Engine has less than 25 hours on it. Engine currently stuck. Local pick up in  Easton  MA.  $49  or offer.
    • Joe Warren
      By Joe Warren
      Wheel Horse
      Service Tool Kit
      Onan Industrial Engines
      ON-420-0556
      Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
      $129 plus shipping cost.
      Message me if you are interested in purchasing. Thank you. Joe
    • Merl
      By Merl
      Newbie here and I have a 520-H that runs, but needs some TLC and some minor things fixed and/or adjusted. It comes with a like new tiller that I believe has only been used once and has paint still on the tines. I am the 2nd owner and I have personally never used the tiller. I am selling my previous home that I rent and where it has been stored. My current home's yard just isn't big enough to use a rider and I need to find a new home for it. I want to sell them together to simplify and I need them gone in the next 2 weeks. Please reach out with any questions and I'll do my best to answer. I am definitely not as knowledgeable as most of you on this forum, but figured somebody would like to fix it up, part it out and/or needs a tiller. Please email or text.
