JPWH
Lathe advice needed
19richie66
:text-yeahthat:
Sarge
Nice score - that's something that will last far longer than that lawn mower and frankly is more useful. Take some time to get to know the guts of the machine first and address any wear items now - once you have it in service it's harder to put it down for a time to do any work on a machine.
I missed a later model Logan awhile back that was a little larger than my Enco - still mad about it too as it was it very good condition with little to no wear, ugh.
Sarge
pacer
Logans like yours are/were are in the "home shop" (South Bend, Atlas, Sears, Clausing, etc) category and are a bit on the 'light duty' side --- but even so its amazing how much 'light duty' parts you can turn out with it - bushings, clevis, threaded rods, etc, etc.
I sometime think back over a project/rebuild and remind myself of just how many items I was able to whip on the lathe out in minutes that would have taken many hours/days to run down - and pay for! I seriously doubt I would stay in this hobby otherwise.
As for rust --- for some years I would scrounge up metal lathes (and other shop machinery) that had been neglected with rust usually being quite bad. I never had a machine that I couldnt get the rust removed and come out with a nice tool. That wouldnt apply to all the other problems of worn broken parts!!! Rust will take some elbow grease - sometimes a LOT! - but from the looks of yours should be a breeze to clean up.
My personal lathe is a 12x13 South Bend that went through Katrina!! Talk about rust!! I have now been using it for some 6 years and while the bed is visibly pitted it is a remarkably accurate and functional tool.
And I agree, that box of "stuff" is a treasure!!
JPWH
I have a question about the support for this lathe. I am thinking about making the legs out of 3x3x3/16 tubing and weld an 8x8x1/2 plate on top of the legs at each end to mount the lathe to. Each end will be 8" at the top and 18" at the bottom with cross supports about half way between top and bottom. Basically the same as the cast legs would be. Does anyone see why this would not work?
19richie66
I cant see anything but it sounds good. 👍
  • Haha 1
JPWH
I can see it plain as day in my mind. lol  Maybe I need to draw a picture?
JAinVA
Can you give us some overall dimensions for the lathe and its estimated weight.I got a old Logan lathe years ago that had been stripped of all useable parts except the catch pan and legs.The legs for each end were way heavy cast iron.If you use 2 3x3tubes for each end you should be fine with what you propose.A single tube at each end would be a little iffy.If the belt drive is at the back or top of the lathe then it could be tied down to a work bench top.If the drive is of low mount a table top could still be used.Luck,JAinVA
Edited by JAinVA
JPWH
The overall length is about 36". It is 28" center to center to mounting plates. I'm guessing maybe 300 lbs. Total weight. I was thinking 2 3x3 tubes at each end like an A frame. Then a frame between the two ends so a shelf can be utilized under the lathe.
JAinVA
 Just my opinion but that should work.A catch pan should be under the ways as well.At around 300 lbs you should be able to figure how much spread needs to be at the legs for stability. If you decide to put this assembly on casters count on it to rock some.My 10" Southbend was rock solid until it got wheels.Not bad but different.There is no doubt your lathe falls into the light range but I saw an early 10" Southbend  making parts in a commercial setting working day in and day out.It would not have been there unless it worked and made money.I got your PM and if you need some help just ask.This may be off subject here.
Edited by JAinVA
JPWH
Thanks. I am confident the legs will support the weight just wasn't sure about the operation of the lathe. I will have questions about some parts that came with it. I'm sure they are for doing things that I don't know about.
JPWH
The parts in question.
1.
2.
3.
JAinVA
With out holding each part the first picture is some type of boring bar holder.The second and third picture is a tool holder.The large hole clamps the holder to the lathe compound and the tools are held in place by the set screws.The last picture is a boring bar mount.There seems to be a cutting tool at the small end.The large hole in the main block allows the mount to be secured to the compound.If these terms seem to be Greek then you may have some idea of what you are embarking on.I unfortunately didn't get to acknowledge WVhillbillys  warnings.Jeff is spot on
JPWH
I have not tried to actually use it yet but it is finished. I have been buying a few odds and ends as the cleaning  progressed. After cleaning it up I decided I liked the paint just the way it was so I just sprayed it with clear.
JPWH
It's been a while so I thought I would give a little update. I have been working on my shop so I will have more room to work on tractors. After using the lathe for a while and trying to get it like I wanted, I recently made the final modifications on the lathe. I built a work table cart, grinder cart and a vertical band saw stand attached to my vise stand.
20191002_165612.jpg.02126eec7668b44d9fc293e4ae151014.jpg20191002_165648.jpg.568424c379189261a664cf9b2aa7228d.jpg20191002_165707.jpg.d9946698acaabb7471dfb45eaef73cc1.jpg20191002_165804.jpg.accac052fe83abb236dd8e583e2888ec.jpg20191002_165822.jpg.2d5502ced27fedeab5832ac64e0a5db9.jpg20191002_165722.jpg.4fb7ccba43f1385953787f9868465b20.jpg
Now I have the tools in order I have a little more work to do on the shop and I can get back to work on tractors.
Jay
Edited by JPWH
bc.gold
Nice window. for the time being and very clean and still in one piece.
Machinists always use a tool box made of wood with felt lined drawers, wood prevents the tools from sweating.
Is that a cam lock or threaded chuck.
Edited by bcgold
JPWH
Plexiglass protects the window. Threaded chuck. I also have a wooden box. Just not big enough.
WHX??
Nice Hank....really like that mobile welding table! :handgestures-thumbupright:
bc.gold
With a tool post grinder your only limited to your imagination, resize a connecting rod, grind engine valves or even a crankshaft, resurface a worn hydraulic pump etc. etc.
These often show up on ebay.
Edited by bcgold
JPWH
Thanks for the video. I will look into the tool post grinder more.
Looks like it would be a worthwhile addition.
Jay
bc.gold
Operating the lathe in reverse what keeps the chuck on the spindle.
JPWH
I have not had to run it In reverse and i don't plan to.
bc.gold
Sooner or later you'll be doing some threading, often it is difficult to engage the half nut on the correct index dial and its easier to reverse the lathe keeping the bit indexed for the next cut on that precious thread you've spent hours choosing and setting up the change gears.
Your lathe appears to be equipped with a drum switch and the way it's set up caught my eye, I would have wired it so that forward brought the handle of the switch towards me, which is the norm for a right handed person.
Being opposite to the norm should someone not accustomed to your lathe accidentally reverse it during start up could uncouple the chuck from the spindle.
The compound slide needs to be set up properly as it is now it looks like an accident looking to happen.
Edited by bcgold
bc.gold
There are plenty of YT videos showing how to make an indexing plate for the metal lathe, but choose one that also showed the use of one.
JPWH
Thanks for the video. Another idea to look into. As for the drunm switch that was how it was when I got it. Good eye on the compound. I had just finished making a rope guide for a little tigger at work that was originally plastic.
Jay
