JPWH 5,295 #151 Posted October 13, 2017 9 hours ago, Aldon said: Looks good! Big show is only 8 months away:-) I hope to be started paint before cold weather. Just need to seal the hydraulic tank, rebuild the battery tray, rework the wiring, and fill the hydraulic system to give it a test run. 9 hours ago, elcamino/wheelhorse said: I will be glad when the Big Show gets here so I can see your great work. I look forward to meeting you then. 1 Share this post Link to post Share on other sites
953 nut 51,541 #152 Posted October 14, 2017 On 10/13/2017 at 4:44 AM, JPWH said: hope to be started paint before cold weather I can identify with that, fortunately we do have a few warm spells every winter. 1 Share this post Link to post Share on other sites
JPWH 5,295 #153 Posted October 14, 2017 I may be closer than I thought. I started final assembly today after I prepped and sealed the hydraulic tank. That needs to cure 4.or 5 days before I add hydraulic oil. Also prepped and sealed the new 854 tank while I was at it. 1 Share this post Link to post Share on other sites
JPWH 5,295 #154 Posted October 16, 2017 I had to get creative for the 30 amp bus on the fuse block. Wiring is done except fuel pump and light switch. 4 Share this post Link to post Share on other sites
JPWH 5,295 #155 Posted October 17, 2017 The hydraulic hoses I had made fit pretty good. I figured I had better install them before I installed the battery and that also gives them a chance to form before I put pressure on them. I left the tank open to let the sealer cure a few more days. 2 2 Share this post Link to post Share on other sites
19richie66 16,880 #156 Posted October 18, 2017 Are those stock style hose fittings or did you use adapters to bring it up to newer fittings? Looks really good. 1 Share this post Link to post Share on other sites
JPWH 5,295 #157 Posted October 18, 2017 (edited) They are standard jic fittings. I took the original fittings to a hydraulic shop and purchased the 2 port sizes I needed then had the hoses made to custom length. Edited October 18, 2017 by JPWH 1 Share this post Link to post Share on other sites
JPWH 5,295 #158 Posted October 22, 2017 Fuel pump mounted. Battery box repaired. Drove it to the backyard for a few photos. 4 8 Share this post Link to post Share on other sites
19richie66 16,880 #159 Posted October 22, 2017 Very cool Jay! Now is this one going to get done up all nice and pretty or is it going to stay in work clothes, or a little both?. 1 Share this post Link to post Share on other sites
JPWH 5,295 #160 Posted October 22, 2017 Thanks Richie. It will be torn down to the frame, transmission opened and inspection, new seals and anything else needed and new clothes. Still will be a worker. 1 2 Share this post Link to post Share on other sites
19richie66 16,880 #161 Posted October 22, 2017 Trying to come up with something we could do here for a "central florida meet n greet". Just wouldnt want a couple guys to show up and stand around sweating. I have plenty of wheelhorse stuff to play with, chop on and weld. The cogs are turning. 2 Share this post Link to post Share on other sites
953 nut 51,541 #162 Posted October 23, 2017 5 hours ago, JPWH said: Drove it to the backyard The "12" lives! 1 Share this post Link to post Share on other sites
JPWH 5,295 #163 Posted October 23, 2017 (edited) A short walk around video. https://youtu.be/u8HpLrkUEOU Edited October 23, 2017 by JPWH 2 1 1 Share this post Link to post Share on other sites
JPWH 5,295 #164 Posted October 24, 2017 I filled the hydraulic system to test it. Everything works but it is a little slower than I would like. I used a larger pump pulley than I had before so I will change that first and see if it helps. Also wired and installed the high / low light switch. I must say i like the option. This will complete the modifications. Thanks for following along. Jay 1 1 Share this post Link to post Share on other sites
AMC RULES 36,944 #165 Posted October 25, 2017 Great work...congrats Jay. 1 Share this post Link to post Share on other sites
Pullstart 59,570 #166 Posted October 17, 2018 What an awesome build! I am glad I read Kelly’s block identifying thread again, that lead me to finding this build, which I then binge-read! I hope all is well @JPWH, looking forward to seeing more progress! 3 Share this post Link to post Share on other sites
JPWH 5,295 #167 Posted October 18, 2018 Thanks @pullstart all is well just been too busy to have any tractor time. I have been working on my metal lathe so I can make parts for my tractor projects. Too much windshield time for work right now to get much shop time. Jay 2 Share this post Link to post Share on other sites
JPWH 5,295 #168 Posted September 13, 2020 It has been almost three years and now I am about to get back on this project. I have added on to my shop and have organized everything to gain more room to work. The final project is adding a small closed in lean to for my 2 air compressors and install pipe to three locations in the shop. I have about 2 days work to finish this project then back to tractor work. Jay 3 1 Share this post Link to post Share on other sites
19richie66 16,880 #169 Posted September 13, 2020 Glad to see you back in action Jay! 1 Share this post Link to post Share on other sites
953 nut 51,541 #170 Posted September 13, 2020 On 10/18/2018 at 6:11 AM, JPWH said: been working on my metal lathe So, it has been two years, how are you doing with that lathe? 1 Share this post Link to post Share on other sites
JPWH 5,295 #171 Posted September 14, 2020 Hey Dick, I have it set up pretty well to suite my needs at the moment. I found out my eyes aren't as good as they used to be so I built a frame and installed LED strips to light up the lathe. After some tooling purchases along the way I have been able to make whatever I need so far and even make some parts for my son so he can keep customers going when parts are NLA. Jay This is the metal storage that is to the right of the lathe. 4 Share this post Link to post Share on other sites
JPWH 5,295 #172 Posted September 28, 2020 My wife and I were coming home Friday from getting the sutures removed from my arm and seen an Estate Sale sign. I'm always looking for old tools and such so we decided to take a look. I found a twin to the one I have. Now I can build a tandem disc. 3 Share this post Link to post Share on other sites
JPWH 5,295 #173 Posted October 12, 2020 I have made a little progress on the air compressor lean to. I have the siding on. I made up a jig to keep everything square and tacked welded two door frames together. 2 Share this post Link to post Share on other sites
JPWH 5,295 #174 Posted June 19, 2021 Finally finished the compressor lean to. Now I have another project I'm working on so I can finish the restore of an old glider swing that belonged to my wife's parents and for tractor implements and such. 1 Share this post Link to post Share on other sites
