HamptonT
Implement compatibility between 314-8 and C-105?
HamptonT
The two machines appear to be compatible. Same Wheel base.
Also, does anyone know if the rock shaft kit is standard on the C-105? Or the axle attachment?
stevasaurus
I believe what ever works on one will work on the other.  The 314-8 is the same as a "C" series...just different years.  :think:
1995 520H+96+97
:wh::rs:
