HamptonT 33 #1 Posted March 24, 2017 Anyone know if a grader blade for a 520xi will fit on a 314-8? They have different model numbers but look exactly the same. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,444 #2 Posted March 24, 2017 I use this one on a C-120 8-Speed so it should fit a 300-Series. Had to move the rear 3/4" cross bar ahead 5". It is welded in so I just cut it out. The new bar is held in with pins in new holes drilled in the rear frame. If I drill out the remains of the old welded in pin it will still fit the 5xi models. Garry Adding I already had the rear axle quick hitch for the dozer blade on the C-120 and this 5xi modified grader fits. I don't know if a 5xi rear quick hitch will fit on a C-Series or 300-Series but I would doubt it. Share this post Link to post Share on other sites
