HorseFixer
ARK OF THE DIVER
HorseFixer
Last year while doing some house cleaning I also did some Horse Trading. I Acquired this Loader and the best I can tell it is an ARK 500 Loader. It is missing the undercarriage mounting so no doubt I will have to fire up Ole SPARKY and do some fabrication. I am in need of a MANUAL for it if indeed it is a ARK 500. I also will be mounting this up on a Newer 520 with gear reduction and front swept axle. I have a couple 520's both of which  have one foot in the grave. One is late 80's and the other early 90's the 90's model has a running Onan but is Suspect on how good of an Engine it is. I would have to combine both tractors to make a usable machine. I would prefer to purchase a Better 520 that needs nothing done to it for this project just because this year I have enough on my plate. At that point the others will most likely be parted out Just to keep what I have running. Anyway If anyone has a very fine 520 I may be Interested. I also would love pictures of the undercarriage framework and measurements for a 520 if possible. And last but not least I could use a Manual for the loader.
Thanks ~Duke  :handgestures-thumbupright:
  • Like 8
JoeM
Duke here is one of my 520 undercarriages used on the FEL I built. It worked pretty good. The tubing is 1 1/2" x 1/8" thick except the cross bar is 3" x 1 1/2" x 1/8". I ran the tube out the back to attach the oil tank and some plates for weight. I used the attach a matic on the front, but for some reason I didn't trust it will all the down force exerted by the frame, so I added a couple angles from the frame to the cross tube. The frame width worked out just so the pump could be mounted on the side with adjustment. I think the ARK Loaders are just a hair wider than mine but you got that unit to measure from.
Any Q write.
Joe
IMG-20121006-00067.jpg.2e88add0a3791f59cd03665e71076cfe.jpgIMG-20121006-00069.jpg.9c141724b7e43d4ba415b05fc1981c22.jpg
58cd9e2ce0595_PumpandAnglesupportcliptoframe.JPG.62f4741f218e2efb247a430dddb4b334.JPG58cd9e2c02865_LowerFrontFrameandPumpMount.JPG.45d6e658613d4498c96acca7d3661fb4.JPG
IMGP0255.JPG.ea341f9c302d25dd0a64bd724fa921d9.JPGRockChuckerIIpic1.jpg.b6778f994f3045bb1429c99b9e5d3ec2.jpg
  • Like 7
stevebo
Duke,
You may want to consider finding an XI with power steering. I love my 522XI with loader. Power steering is the cat's meow.
  • Like 4
DTOM
If you can give me an e-mail i can scan and send you some of my collection of Ark loader paper work.
maxiblue
That loader looks liked it is off a "D" series tractor looks like the under the frame connects are there for that. but I may be wrong it does look like on my D-250. I do have an manual for my loader.
Edited by maxiblue
DTOM
The "D's" are the 550. its more like a "C'' series.
The 508-H, 508-T, and 508-QM are for the long frame late 60's through early 70's.  The 510-B and 510-QM are for the GT-14's.
  • Like 3
HorseFixer
Any Q write.
Joe
Thanks Joe I will look this over and no doubt will get back with you on some questions.
Thanks Tom PM Sent
DTOM
Take a look on the inside of the upright pillar on the right side.You should see a manufacturers plate, saying 510-? or 508-?. If not, measure between the two tabs on the front bracket that bolts to the frame. If its 8'' between then its for the GT-14 or 7'' for a long frame.   I believe its for a GT-14.
maxiblue
good eye DTOM , they seem alike to me but know not to much about the other tractors sorry
DTOM
It helps to a few loaders and a few tractors to look at in person.
  • Similar Content
    • edwroy
      By edwroy
      Needs some help. Purchased an ARK Loader - Model 550 Serial # 573 - anyone know what year this might be?
      Thanks,
      Edwroy
    • boovuc
      By boovuc
      Well the Grange Fair was a short visit!
      Started uninterrupted work on the loader at about 1:30 this afternoon. Finished at 8:20! It was worth it. After some cutting, grinding, filing and minimal cursing because I had no time constraints, I got it on. Thanks to my Karen who slid the tractor under the mount while I held the frame up. (Never made the stands. Used the brace arms to get it off the blocks). No leaks, no seeps, no noises, and full function of everything. Pump is very quiet and barely moves the vacuum gauge on the tractor. Much less work for the motor than my 48 inch mower deck.
      I didn't put the rear weight on so I took it easy and made sure everything was primed in the lines. Plenty of down pressure and fast movement. A big thank you to Malmac, Scott, Wallfish and the others who offered advice and posted pics of their loaders. The biggest pains in putting this on a 520 since it wasn't factory designed for any of the Onan powered tractors was the pump mount and the lever release/lock Attach a matic that is used on the newer tractors and the 1991 520-H. (My 1992 416-8 didn't have the lever design).
      It required cutting out a long skinny triangle from the thick metal original sub frame to allow alignment of the frame holes and shortening the actual lever. (The frame cut took three cutting disks and a good portion of a fourth). I also had some issues with the nut/bolt used on the front mounting bracket. The first frame hole on each side has VERY little room to start a nut. (Because of the gear reduction steering assembly). On the positive end, the factory brace arms leave plenty of clearance around the Onan and hood. My suction line to the pump will need moved since it is in harms way. I think the pump is OK where it is at with a guard to be made soon. I'll work it harder on Monday and really heat the oil up and check again for leaks or seeps again. I do have to weld a wallowed loader lift cylinder pin hole but even it isn't too bad. The others are real tight. Not bad for as old as it is and for 500 bucks.
      This was always a real want for me so please excuse my over exuberance. This makes the beginning of the work week a joy! It might take until noon at work tomorrow to wipe this grin off my face!
    • chevyaddict83
      By chevyaddict83
      So, i ended up rebuilding curl pistons, worked great. Now, having lift issues. If i pull on the lift lever slightly, i still get the arms to go up. If i pull all the way back, the whole thing drops. If i leave it raised and fill the bucket, it stays up and dumps fine. Is it something in the control valve? Maybe an adjustment?
      Sent from my LG-LS980 using Tapatalk
    • prondzy
      By prondzy
      So i have an ark 508 loader on my c160. I was wondering if any of the other Ark FEL owners could tell me if there is a "float" postion in the spool valve?
    • bo dawg
      By bo dawg
      Is it hard to pull apart to replace seals? Any tricks? Or things to watch for?
