shallowwatersailor
Finally Some Snow!
elliot ness
Super nice Machine.:text-bravo:
pfrederi
24" and wind. That 16hp Kohler was working the governor...right up until the belt broke.  Replaced that (by the way what engineering genius made the drive pulley so close to the housing you have to remove it to put the belt on!!!)  Finally broke through to the road (only one pass by the town plow. Then the cable for the chute pulled out of its clamp.  i do not have a cable cutter and the end was frayed so i couldn't get it back together right away.  got her back to the shop (snowblowers do not make good snow plows thank the heavens for the 10 pinion ltd slip..  Got the cable rethreaded but i was cocktail hour...besides i  ain't going nowhere for the next day or two.
Will be back out i the AM to do it all over again
  • Like 4
aHorseofCourse
I am in the same boat, I was all excited for a good snow.  Supposed to get 18-24" of snow.  Ended up with 8-9" of sleet.  What a disaster.
shallowwatersailor
In 1993, Toro had to change the model number on the 42" snowthrower (#79360) because there was now an electric PTO with a different size PTO pulley. That meant the pulley on the snowthrower was made smaller. It is possible to change the belt without removing the pulley on that model.
bmsgaffer
How did those tires do!? I will likely not get enough snow this year to try them out. :(
shallowwatersailor
The tires are great! The only additional weight added on the tractor are the four suitcase weights on the rear and the weight of the cab that I estimate at about 45 pounds. I haven't put the wheel weights back on since getting the Kenda K502 Terra Tracs, and have never loaded them. Today would have been a good day for chains with the ice underneath but I never lost traction. I am adding pictures I grabbed at my neighbors house that has the steepest driveway. In fact, I had it in Hi range (forgot to switch to Lo!) because of traveling down to that house. Still climbed right up that driveway.
  • Like 4
bmsgaffer
That's great to hear! Thanks for the update!
Ed Kennell
I put a smaller pulley on my thrower to increase auger RPM by 10%.        The side benefit was, I can now change belts w/o tools.
  • Like 3
roadapples
And only six days till spring.. dang groundhog....:bitch:
  • Like 3
JERSEYHAWG /  Glenn
we had about 7 inches of snow then sleet and rain on top. a tree snapped across the driveway taking the power lines out and snapping a power pole in my backyard. i spent the day watching the lineman work, new pole, redo the lines.   Ohio Edison power, shout out to them. in from out of state to help JCP&L.  These men worked all day here, couldnt give them a coffee even. Got my respect.
John, glad you had some fun you dog you.
My son Mike got on the C175, but only in front on the house. lol
Glenn
Edited by JERSEYHAWG / Glenn
  • Like 5
953 nut
When I lived in Florida we had several out of state line crews restore power following hurricanes;  real heroes!
12 hours ago, shallowwatersailor said:
We were in the 8-12" forecast range but was actually 4-5"
Confucius say;    "Better to be over prepared than overwhelmed!"
  • Like 3
Ed Kennell
                                      Good to hear you had quick help.       Did they also clear the tree from your driveway Glenn?
                                           Home owners insurance will pay for downed tree removal on driveways and fence repair.
JERSEYHAWG /  Glenn
yes Ed, they cleared it off the driveway entrance to get the trucks in. but left it on the property, ( i am not complaining )
they also plowed the driveway. they thought it to risky to drive in.
I notified insurance co. a real mess here.
Glenn
oldlineman
Thats what I did for 41 years, the best part of storm work was when we turned the power on and everyone cheered. It makes you feel good to help people when they need it. Yes give them a big hand 16 hours on and 8 off in bad weather is hard work and very dangerous, but the end result is worth it.
  • Like 5
  • Similar Content
    • neilevans1971
      By neilevans1971
      42in Snowthrower #79362 for sale
      You pick up, as I cannot deliver.
      Lot's of fun to clear a sidewalk in one pass or driveway in just a few.
      I have the manual, belt and attachment parts that go with it but are not pictured. All are in good working order.
    • Berco
      By Berco
      Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
    • gfullz
      By gfullz
      Hey guys! new wheel horse owner here. I picked up a 2001 523xi that came with a berco subframe. I happened to find a 40" compact berco that was hardly used to slap on it only I'm not sure where to start as there are no resources for this that I can find. I'm mechanically inclined, rebuilt the injection pump, injectors etc... as I purchased it non-running as it wasn't receiving any fuel to the injectors (it runs amazing now btw).
      so for starters I'm going to go out on a whim here and say that this will require the mule drive or "pulley box". and I've got the rest of the parts in the picture. The parts of the subframe that look to bolt up seem so narrow compared to the hookups on the rest of the tractor. Any help is greatly appreciated.
    • sfox17
      By sfox17
      Hello How much is a 79361 Ser. 5900 worth? it's in good shape. The only thing wrong is one impeller blade needs to be straightened. I'm just looking for a ball park figure if the blade was straightened or not. Thanks Sean
    • Berco
      By Berco
      I have an oil leak on my Kohler CH22 in my Toro 522XI (see video). I put in new head gaskets to remedy low compression. Then upon first start i had a large oil leak. It seemed to come from the aft oil seal. So i pulled the engine again and replace the seals. I re-installed the engine again today and the leak is still there. This is the leak now: https://youtu.be/pi382fXVXPQ What could cause it? I did blow out the air line from the fuel pump with compressed air into the crank case to clan out any debris. Could that have caused a leak this bad on the oil pan gasket? or another location? thank you all in advance!
