carlosking450
Wheel Horse 702 from Spain
carlosking450
Bueno hemos seguido con la restauracion despacito pero bien,esta vez a tocado preparar algo de chapa.
  • Like 3
carlosking450
After several weeks I have managed to advance a lot.
<blockquote class="imgur-embed-pub" lang="en" data-id="a/r42fY"><a href="//imgur.com/r42fY"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
  • Excellent 2
carlosking450
The gearbox is in very good condition only if you change bearings and seals
  • Like 6
C-121uk
Excellent job!
carlosking450
Very thanks
carlosking450
Good morning friends, I need to continue with the repair of my 702 I would like to know how the cables of the starter and accelerator are placed, could you put photos to me? thanks
wheelhorseman
Edited by wheelhorseman
carlosking450
Thank you wheel horseman but I need photos with the fasteners to go by placing the throttle cable and starter
wheelhorseman
Ok I can get some this afternoon
carlosking450
thank you very much very kind
wheelhorseman
Is this what you need?
carlosking450
Yes very thanks¡¡¡
carlosking450
Texas Todd
¡Hola Carlos! Se ve genial. Has hecho un muy buen trabajo. Sigan con el buen trabajo!
C-121uk
¡Muy Bien!
carlosking450
On 13/10/2017 at 12:40 AM, wheelhorseman said:
¿Esto es lo que necesitas?
Hi, my friend, I have a question about the accelerator cables that I bought, the tip of the new cable is straight and the old one is bent like an "s" so that it does not escape, should I bend it with a pliers to the new cable?
carlosking450
Hello, can someone tell me what has a mobil tab on the top feet?
Texas Todd
If I understand what you are asking, the pedal engages the PTO and the tab folds over to hold the pedal down, thus keeping the PTO engaged.
wheelhorseman
Yes you are referring to the throttle cable they come straight on the end so you can cut them to the length so to answer your question yes install it in place then cut it to the length that you need then put the bend in it - here is what he is referring to.
carlosking450
8 hours ago, wheelhorseman said:
Sí, se refiere al cable del acelerador, vienen directamente en el extremo para que pueda cortarlos a la longitud suficiente para responder a su pregunta. Sí, instálelo en su lugar, córtelo a la longitud que necesita y luego colóquelo. Aquí está a lo que se refiere
hello friend, I imagined it but I wanted to make sure, thanks!
10 hours ago, Texas Todd said:
Si entiendo lo que está preguntando, el pedal se acopla a la toma de fuerza y la lengüeta se pliega para mantener el pedal hacia abajo, manteniendo así la toma de fuerza activada.
If I meant that, but mine does not have a PTO, thank you
