tommyg
dip stick dysfunction
OK, for the second time now, something inside the tranny on my D180 has broken the dipstick from the "full" mark down. It's currently inside the bottom of the transmission. Anyone have any thoughts on why this is happening? The first time it happened, I noticed that the threaded tube that it travels down was bent. So I thought that was the issue. But the new one is perfectly straight, and the same thing happened again.
Just measured my D200.  The stand pipe sticks 3" up from the tranny.  The dipstick measured from the lower lip of the cover to the tip is 5-3/4.  How long did it take to break??
The only thing back there is the differential gear and the dip stick is off to the side of it.
Edited by pfrederi
The same thing happened to my D200. It was the pinion bolt (s) in the rear end had worked loose and started contacting the dipstick and twisted it into a pretzel. The rear end had to come out and be split open to repair it. I think this was a common problem with the early D series.
Ugh. That is not the news I wanted to hear. I'm not sure when it happened. I just noticed it yesterday. Trying to find out how much oil is supposed to be in there is driving me crazy. I changed it and put in the amount listed in the manual. Yesterday, I noticed oil oozing out of the dipstick tube. I haven't run the tractor for at least a month. I pulled out the dipstick and oil was just spilling over the top of the filler tube. That's when I noticed the dipstick issue. I stated the tractor and the level went down quickly, I suppose as the pump sucked it up to the front.
Edited by tommyg
I think mine holds around 4 to 5 quarts but I don't remeber exactly. Better check for those loose bolts or severe and expensive damage could occur. Good luck buddy.
It is hard to get a view down the dipstick hole...maybe with a mirror or one of those camera thingys.  i hope Mike is wrong but what he said makes a whole lot of sense
edit:  jack her up and release the tow valve..  stick a rod/wire etc that is at least 6 inches long down the tube then spin the wheels..any noises/contact???
Edited by pfrederi
I actually have an inspection camera. That's a good thought. I can put it down the filler hole (it has a light on the end) and spin the wheels and see what's going on potentially before I have to crack it open. Great idea!
Mike, I know it's at least 5 quarts. All I know is that it's a the right level when I run it, but after the oil drains back down from the hydropump, it's oozing out of the dipstick tube! So I'm not sure how to measure it. Obviously, I have too much, even though I filled it with the spec'd amount.
Edited by tommyg
Well I did check my D Series owners manual and it shows 6 quarts for the transmission. However, the manual does mention to constantly check the dipstick for proper fill level because of the fact that even after draining  the system, some oil remains. So I would assume that the 6 quarts is for a totally dry system which ours would not be totally dry when simply performing a basic service. I guess that's why mine only holds around 5 quarts or so including changing the filter. Dont worry about the fill level when running it. Just make sure it is at the proper fill level with the engine off and any hydraulic cylinders should be in the retracted position. An inspection camera will certainly reveal any problems inside. If you have to split the reareand, my wheel hubs were really tough to remove. May want to remove the set screws and start applying some good penetrating oil. Best of luck friend.
I would comment, but anything I have to say about dipstick dysfunction or measuring your dip stick would certainly end up being deleted, I'm sure :popcorn:
Have you had a chance to look inside yet???
I've been down the hub removal road before. Before installing them again, I smeared them with antiseize compound. I'm  hoping that'll do the trick if I have to open it up.
Not yet. I'm in the middle of building a vanity for the master bath. It's sucking up all my time presently. Hopefully one night this week.
OK, I had a chance to jack her up and take a look. Had to drain some of the oil first, but upon first inspection, there's nothing that jumps out at me that could potentially be the problem. I have to pick up a micro-sd card for the inspection camera so I can record some video of what I see. Maybe someone here can see something that I'm missing. Stay tuned.
Here's the dipstick. Where it snapped off as about 4 7/8". Can anyone measure theirs just as this one is measure and tell me what the overall length is? Where this one snapped is exactly at the "full" mark.
If we make it up to 10 degrees i will go down to the barn and measure it for you :P
Last night was the coldest of the winter but is supposed to be almost 60 on Tuesday  crazy.
Anyway does this help??
Yeah, that does. So it looks like before the break, it was the right length. That's what I was wondering. Hope to post a video this evening on the inside of the tranny. For what it's worth, it was 12 deg here last night. And yes, 60 by Tuesday. Typical March weather in NE Ohio.
Here's the video looking down from the dipstick perspective. Anyone see anything? I can't see anything awry.
transmission.wmv
Edited by tommyg
uploaded a different video format
Nice movie...but I didn't see a thing.
Does the dipstick fit securely in the pipe?   If it does not seat tightly it may wiggle about and then come in contact with one of the bolt heads
Don't really see anything amiss - not even any scars on the diff bolts ? I wonder if someone just didn't pull the stick clear of the tube and broke it off in the process ?
Nice camera work , btw...
Sarge
I'm going to drain the rest of the oil and see if I can retrieve the end of the dipstick. I'm  not positive, but I can make out a silhouette of a shiny piece of metal that looks to be about the same size sitting in the oil right  below. Assuming I can retrieve it, I don't see any reason to pull the case apart at this point, would you guys agree? I found another dipstick on ebay and have it ordered. If it happens again, though, I'm going to have to figure something else out.
If it snapped right at the full mark it was probably bent at one time and straightened - with that mark it acts like a score line and can make the metal fracture if pushed too far . I've seen a lot of dip sticks break the same exact way on a variety of mechanical things - it's more common than you think . Some of the older International truck chassis engines were known for losing the ends of their stick , to be later found inside the grenaded oil pump...
Sarge
Sarge
Yeah, I get that, but I'm now working on my third dipstick. Coincidence will only take you so far. Nevertheless, I don't see anything that would warrant me tearing that thing apart as long as I can get the missing dipstick end out of the transmission case.
I don;t see why you would have to open it up if you can retrieve the broken off tip (assuming it isn't really mangled)
Actually looking at the broken off pies could be useful.  The clean break combined with an intact not damaged tip would indicate an one time hit,
I assume you have jacked her up and tried spinning the wheels to see if you hear any sound of contact.
I'll post a pic of what I find. It looks like a clean break on filler neck end of the stick, but it is bent a little if you scroll back up and look at the pic I posted with the ruler. That might suggest something. What, I don't know.
  • Similar Content
    • By Sarge
      Fast question ...
      Per the IPL for the 6-1141 and 6-1131 54" & 56" blades - how is everyone pinning the rear blade lock arms so they can't unlock the blade ? I've ran into problems with this thing before wanting to unlock itself and drop the blade half off the tractor. It seems when back dragging rough pavement, especially if I back into a snow bank the thing is moving those locks out of position and allowing the frame to drop off. The only reason it stays at least somewhat under the D is the lift arm , but getting it back into position is no fun due to the weight of this thing and especially out in the snow/cold weather. Last time I had to drag the thing back to a clear area so I could wrestle it back into position, lift the frame and lock it again. I did wire them shut for now, but don't trust it and I use it to back drag quite a bit on rough areas I don't want to ram the cutting edge against and risk damaging the rear axle differential or anything else. Mine has been rebuilt with a new cutting edge of 1055HC and the frame is highly beefed up - most of it is now boxed in and the thing has gained nearly 50lbs of steel. It cuts great, almost too good but that random dropping it off is starting to irritate me - need some ideas here...
      The smaller 42" and other frames lock from the other direction - so to speak. The brackets are also drilled to accept large hair pin cotters to keep those locks in place - I see no way the bigger blade frame is designed for that, unless I'm missing something ?
      Sarge
    • By Sarge
      Ok - the UL-1 batteries won't cut it for turning over the big cast iron Kohler twins - got one that is only 6mo old and it's basically shot already . One start cycle and if it doesn't fire it's done - needs to be jumped . Since it's mounted above the Sundstrand pump and so close to that thumper engine I'd assume the vibration is just killing the plates . At a rate of 2 batteries per year - that doesn't work out very well and the rotating mass of that engine just draws far too much from the battery - even with a new starter .
      From the BCI group number chart and some dimensions of what can fit in the tractor physically I come up with a Group 26 battery - what is everyone using in their twin cylinder D's ??
      I see an equivalent Deka runs about $80 - anyone tried that size on one of these D's ...?
      Sarge
    • By Petes Horse
      Getting my mess of a d160 rebuilt and found the source of play in my steering.
      This may also explain the oddball rim.
      Bottom race. Or is it races now?
      -----------------------If you don't like modded OEM parts go no further, there be carnage ahead!----------------------------------------
      So I went on a hunt for a replacement. Wow those are expensive. No standard bearings even close.
      Turns out 3/4 x 1-3/8 x 1/2 wheel bearings fit perfect because of their flange. Well almost. The ID is a little off.
      Adjustment needed. I already ground the lip off. I believe the lips were to hold the bearings for assembly.
      The flange of the bearing sits nicely in the adjustment cup.
      Looking down into the cup with bearing in it. Flange side down.
      Worm alignment with sealed bearing in cup on left. Same as new.
      The cotter pin hole doesn't line up but there is enough room to drill a new one.
      End view with bearing installed.
      To install both top and bottom bearings you have to grind or turn a good portion of the shaft and the lip on the other side.
      It's only .030 so not to bad.
      Both bearings installed. Fit nicely against the shoulder of the race on the worm.
      Worm alignment with both bearings installed. Old outer races removed. tightened snug. Still has full travel and is more centered.
      No way to install cotter pin. but my alignment cup was so tight it will not come loose. I'm lucky I got it out.
      End cap with both bearings installed.
      Hi-tech cap removal tool one ground down wood bit.
      The sealed bearings sit up against the shoulder of the race and the bearing flanges face away from the worm.
      The flange may need adjusting depending on who made it. There is no inner seal so it can be greased like usual.
      I'm not sure how they will hold up to thrust loads but for 6 bucks I'll risk it.
      I didn't grind near the original races at all so it can be put back to original if need be, minus some metal anyway.
      Welp, back to painting parts.......
    • By Petes Horse
      I've been looking for a while. The bolt holes just line up and the wire is a little tight between the fender and light. No drilling though.
      They were at Rural King. I think about three bucks each. Optronics MC42RS RED  Marker/Clearance.
    • By RedWheelz
      This unit starts and runs good, hydros work good.
      Brand new battery, never used.
      Front and rear PTO
      Dual brakes
      3 point hitch
      Hour meter does'nt work. Wasn't working when I got it.
      Email me for fastest reply
