OLDASDIRT
1974 B-100 Automatic
OLDASDIRT
I'm about to remove a Sundstrand Hydro-Transmission Model # 90-1136....I believe from my B-100. Once the unit is apart I'll be needing parts. The $64,000 question is does anyone have any information on where those parts can be gotten? Parts is parts! Well I'm off to the garage and I'll check in later. Happy whrench'in to all.
pfrederi
WH sold off all parts and responsibility years ago.
LJ Fluid Power 10118 South M 43 Highway Delton, MI 49046-9602 (269) 623-4150 is now the source.  Be sitting down as teh price of some parts is pretty steep.
Why are you taking it apart what is wrong with it.  You need to download the Sunstrand manual here before you start in.  Also the are several thread in the how to section about working on them.
http://www.wheelhorseforum.com/forum/144-transmissions/
daveoman1966
I have SOME Sundstrand parts .... when you get it torn down send me a 'shopping list'.  My direct email is:
daveoman@windstream.net
Here is a pic of the internals.
IMPORTANT..... keep your area CLEAN and be certain to CLEAN all parts thoroughly on re-assembly.  These units are ultra-sensitive to debris of any kind.
KC9KAS
@OLDASDIRT :text-welcomeconfetti: TO :rs:.
The only thing I will add, it to take many, many photos from different angles as you disassemble, as you will thank yourself on the assembly!
  • Similar Content
    • Thatoneguy
      By Thatoneguy
      So I washed my rear end and sundstrand 90-1136 and now the by pass valves leaks when I screw it in past a certain point.  If I screw it all the way in I can sit there and watch the fluid start seeping past it.   I changed the o-ring with an R-04 i believe is what it was.   Do these require some sort of thread sealer? There was nothing on it when I took it out, and when I used the valve to push the tractor in my shop it worked fine and has never leaked. Any ideas would be wonderful!
    • RJ Hamner
      By RJ Hamner
      I found this "field modification" (origin unknown). The dark square that has been wired to the rod is lead that weighs about a pound and a half.
      the 876 doesen't have the friction parts of the later models so I am wondering if this was/is an attempt to dampen the movement of the forward/reverse lever?!?
      Any ideas??
      Bob
