Similar Content
By Thatoneguy
So I washed my rear end and sundstrand 90-1136 and now the by pass valves leaks when I screw it in past a certain point. If I screw it all the way in I can sit there and watch the fluid start seeping past it. I changed the o-ring with an R-04 i believe is what it was. Do these require some sort of thread sealer? There was nothing on it when I took it out, and when I used the valve to push the tractor in my shop it worked fine and has never leaked. Any ideas would be wonderful!
By RJ Hamner
I found this "field modification" (origin unknown). The dark square that has been wired to the rod is lead that weighs about a pound and a half.
the 876 doesen't have the friction parts of the later models so I am wondering if this was/is an attempt to dampen the movement of the forward/reverse lever?!?
Any ideas??
Bob
