Hacksawhero123
Hydraulic control valve question
Hacksawhero123
I need the wisdom from the hydraulic wizards. In my collecting of parts, I have two different styles of "inlet" blocks. This is the block that is marked "in" and gets pressure from the charge pump. The red block in the photo is the one that is different from the factory block on my 1975 c160. Am I correct in assuming that the bolt/spring assembly is a pressure relief valve?  Could this be a power beyond port?  Thanks Fellas.
Mark.
Edited by Hacksawhero123
gwest_ca
I can't answer your question and there is limited info available for these units.
Garry
Hacksawhero123
Thanks Gwest. I forgot that I had downloaded that before. Getting old I guess. I would like to find a valve with the float detent though. Thanks again.
Mark.
R. L. Addison
I think that is to relieve pressure with temp change,(sitting in the sun or such). As the oil gets hot, it expands enough to put unbelievable pressures in the system, and in cases of larger volumes heating, has been known to blow hoses etc. It looks to me like a safety feature.  I think the power beyond would have to come through the return line, as these valves would have to be open centered as charge pump could not supply oil to closed loop to make up for valve plate and other leakage in the pump/motor unit.
Dennys502
The pressure relief valve is used to control line pressure - depending on what psi the system is designed for. Anything over the pressure its set at gets dumped back to tank.
cleat
I have played with the hydraulics on my diesel tractor.
That is a pressure relief valve.
My new loader valve has a power beyond outlet.
However, my old hydraulic valve also had hydraulics downstream for rear remotes and 3 point.
The old one just used the outlet from the valve feeding the inlet to the next valve in line.
My new loader valve with the power beyond uses the power beyond port to feed downstream valves and also has it's own return to tank fitting.
That means I had to add another line back to the tank. Seems to work exactly the same so I am unsure what the benefit really is.
One word of caution. When replacing a hydraulic valve you should hook up a gauge and make sure the relief valve is working and set to proper pressure.
Cleat
R. L. Addison
The hydraulic pressure is set by shims in the pump valve body which controls a cone, to determine system pressure. The pressure adjustment on the spool valve bank can also control system pressure if it is set to a lower pressure than the one in the valve body, as the oil will take the path of least resistance.
The reason I would come out of the return line to any other hydraulic function is there would be no "T"'s needed, and the charge pump has a very limited capacity and more than one action at a time will be slow due to the small volume of this pump. The exception to return line might be power steering, might put it in line before lift valves. Hope you can follow this. If not, QUESTION!
Hacksawhero123
Thanks Fellas. I was pretty certain that it was a relief valve. That block is the oddball in my spare parts bin. The factory inlet block doesn't have the relief valve, just curious why this block has it. If anyone has a spool valve with the float detent they want to turn into cash, please let me know.
Mark.
  • Similar Content
    • Trouty56
      By Trouty56
      Service manual #810242R3
      12 pages 1.52MB
      Dated 09/84
      Also listed as manual 492-4208
      Replaces manual #810242R1
      whlifhyd.pdf @ Toro
      A service manual for the hydraulic lift valves and cylinders.
      Included is a description of the adapters needed to make hoses and where to get them.
      1983 C-145 Automatic model 01-14KE04
      1994 416-H model 73421 Serial 4900001-4999999
      1997 416-H model 73423 Serial 7900001-7999999
    • JasonMc
      By JasonMc
      Hi guys, I purchased my firs WH - a 1976 C-120 Automatic. I have a steep hill on my property and before I go down the hill, I want to understand how my braking system works. I’m aware that this year/model didn’t include disc brakes, so is the breaking purely hydraulic Via transmission and controlled by the speed lever? Has anyone encountered issues with this? Is it safe to use on a steep hill? Any input is greatly appreciated. Thanks!
      Jason
    • jmack
      By jmack
      I'm needing the o-ring sizes for my control valve assembly to my D-180.  Does anyone have a list of these or the McMaster Carr part numbers?
      Thanks,
      Jonathan
    • MS GENERAL REPAIR
      By MS GENERAL REPAIR
      Good Morning Ladies & Gents;
      I operate a Small Engine & Power Equipment Repair Shop From my home in Bridgeport, Ct.
      Yesterday I started repairs on a 1984 +- Wheel Horse C-145 Automatic Lawn & Garden Tractor.
      I decided this would be a good candidate for a repair video series on my new Youtube channel. Since the repairs on this tractor are not the usual carb cleaning & belt replacements.
      Someone suggested that the Wheel Horse enthusiasts on this site might find this information useful and I hope that's the case.
      Problems I'm aware of and being addressed include........... Motion Works Linkages, Hydraulic Implement Controls, Brakes & Parking Brake, Mower Blade Mounting, and whatever else I find as repairs progress.
      Repair Video's have been a tremendous help to me on all types of things that I don't have a service manual for, and if this helps someone then the effort will be well worth it.
      As I post this there are 4 video's in the series. More will be added in the coming days.
      If you find the video's helpful please like, comment & subscribe, so I can mold the channel into a useful resource. It takes a lot of extra time to video document repairs, so it's good to know if it's worth it.
      This Tractor belongs to a repair client and is Not For Sale
      Good Luck With Your Repair Projects..........................Mike
    • Horse's ass
      By Horse's ass
      I can't seem to locate the oil plug on the transmission/hydro of the C161 auto.  Can someone please show me where the heck it is!?!?  I would think it was right on the bottom somewhere near the filter but I do not see or feel anything that looks like a oil drain.....
      Thanks for your help,
      Eric
