Redisbest
522xi engine temp
Redisbest
For those who have or have had a 522xi....Where does your engine temp indicator typically read in winter....27 deg today and mine never left the yellow during snowblowing 6" of powder....I thought it would get in the green for sure....Wondering if eng temp sending unit is working correctly...Boy she throws snow a LONG way.
JERSEYHAWG /  Glenn
mine barely, and I mean barely hits the green. Its almost hard to distinguish.
Glenn
shallowwatersailor
If you have used the tractor for mowing or have mice that may have made a nest, the heads may be clogged with material. The left head is usually the problem given the engine rotation and cooling fan. My 520xi that I bought used would run hot, even in the winter, until I cleaned it.
LRE
The sensor is on the left side in the bottom of the engine.. the sensor itself is no longer available from toro.
